I put together a mosaic of SHG H-alpha images from Oct 6 and 8. The conditions were similar and the quality was high in both cases. The Sun's surface features were ideally suited to SHG imaging on both days (lots of filaments).
Click on the image to see at higher resolution, or open it in a new tab for full resolution.
See viewtopic.php?t=38332 and viewtopic.php?t=38362 for the observation parameters.
It's worth mentioning that our SHG scans in DEC and the slit is quite accurately aligned parallel to the RA axis of the mount. It's quite obvious from looking at these two images how tilted the Sun's axis is this time of year (in fact, it's close to being maximum now, according to the Tilting Sun app).
Full-disk H-alpha SHG images from Oct 6 and 8 -- side by side
- Has thanked: 47 times
- Been thanked: 1525 times
- Has thanked: 8558 times
- Been thanked: 8290 times
Re: Full-disk H-alpha SHG images from Oct 6 and 8 -- side by side
These really are superb. Excellent work.
It is certainly favouring the north there are so many filaments and these really contrast well in the SHG images
- Has thanked: 20813 times
- Been thanked: 10484 times
Exceptional work!
- fulvio.mete
- Been thanked: 84 times
I'm back to solarchat after solving some problems with my email account.
Eccellent work and images, Douglas!
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
