2 post process
2320 X 256 ROI for capture
seems to be finer
SHG caK first attempt with asi178MM
- Has thanked: 57 times
- Been thanked: 1189 times
- Has thanked: 42 times
- Been thanked: 1487 times
Re: SHG caK first attempt with asi178MM
Looks better, I think. What telescope did you use? Is it with a Solex?
The first likes sharper. Is it the same image just different post-processing?
That's a rather wide ROI. You could probably use narrower, like 150 pixels?
I think there are some prominences visible in the top left. Maybe bring those out a little bit better?
- Been thanked: 10248 times
Very promising John!
The first likes sharper. Is it the same image just different post-processing? YES
What telescope did you use? Is it with a Solex? NO - home made SHG my Solex still out of tune (collimator focus)
- Been thanked: 8793 times
