Sunlit, 3h 38 min ballet in animation of Jupiter with Europa, Ganymede & Io, shadows and eclipse
Lets brighten up peoples live with all those lovely pictures of the world around us!
Moderator: Montana
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Post by H-Alpha »
Hi all,
Focused on the solar eclipse, I was almost going to miss the amazing ballet of the "almost sun" and its Galilean satellites. Fortunately, I saw the ephemerids the last moment and rushed to set the C14 to capture it. The seeing was good only in the start of the session, but the spectacle still keeps much of its beauty, I think.
In the beginning Io is to the right and later reappears suddenly to the left, because it comes out of the shadow of Jupiter. Europa (to the left) follows the larger Ganymede.
I post here one of the shots with the four out five members of the Jovian family and the most spectacular long animation further below. I was obliged to cut the animation in three parts, due to bad seeing in-between and also limited space in my hard disk.
Hope you will like it.
Image2022-10-26, Jupiter with Europa, Ganymede & Io, C14 Edge, Barlow 2.1x, ASI 462, 18_48_48 UTC by H- Alpha, on Flickr
Image2022-10-26, Jupiter with Europa, Ganymede & Io, Animation of 3h 38 min, C14 Edge, Barlow 2.1x, ASI 462, 18_44_48-22_22_54 UTC by H- Alpha, on Flickr
Alexandros
Alexandros
Greece
Has thanked: 17813 times
Been thanked: 16953 times
Re: Sunlit, 3h 38 min ballet in animation of Jupiter with Europa, Ganymede & Io, shadows and eclipse
Post by DeepSolar64 »
WoW, the sense of depth is amazing!
Has thanked: 20756 times
Been thanked: 10442 times
This is lovely!
I'll put in the sunlit earth section.
Has thanked: 17925 times
Been thanked: 8894 times
WOW :shock: it looks so 3 dimensional as if you were watching from a spacecraft. That's super :bow :bow :band
Has thanked: 8523 times
Been thanked: 8258 times
Post by Carbon60 »
Absolutely superb, Alexandros. Beautiful work.
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Hi Alexandros, this is a magical sight, I can't even believe that it was taken off the Ground.
Ivan
KMH
Has thanked: 658 times
Been thanked: 766 times
Post by KMH »
Fantastic - beautiful to watch!!!
Kevin
