Today was the same as yesterday, so I chose the same setup and took a few photos.
I hope you won't be bored.
I spend my time waiting for the sun in the clouds by making a new assembly with harmonic gearboxes, so I'm not bored.
The combination of LS80 and Quark etalons provides such a contrast that I don't really know how to deal with it. I will have to find a better way of processing and mainly make flats.
Milky Sun 30.10. - the fun continues.
- Has thanked: 4413 times
- Been thanked: 4012 times
- AR150/F6,TV4x,LS80+Quark,IMX432
- s7c.jpg (1.51 MiB) Viewed 249 times
- s7.jpg (1.42 MiB) Viewed 249 times
- s1.jpg (1.91 MiB) Viewed 259 times
- s1c.jpg (2.01 MiB) Viewed 259 times
- s2c.jpg (1.71 MiB) Viewed 259 times
- s4.jpg (1.15 MiB) Viewed 259 times
- s4c.jpg (1.12 MiB) Viewed 259 times
- s5i.jpg (1.22 MiB) Viewed 259 times
- s5ic.jpg (1.23 MiB) Viewed 259 times
- s6i.jpg (1.21 MiB) Viewed 259 times
- s6ic.jpg (1.39 MiB) Viewed 259 times
Re: Milky Sun 30.10. - the fun continues.
This is her, that is, before giving birth. Weight 7 kg, load capacity 15 kg without counterweights. It doesn't have backlash in gears, it can easily handle an AR150/F8. Time to calm down in the order of tenths of a second. That's the advantage of a non balanced lineup.
- EQHD5a.jpg (537.11 KiB) Viewed 257 times
- Has thanked: 2501 times
- Been thanked: 4925 times
I use combination etalons Lunt LS80 and Quark combo.
- Has thanked: 17955 times
- Been thanked: 17100 times
WoW!!
- Has thanked: 8588 times
- Been thanked: 8324 times
Nice ‘3D’ filaproms, Pupak. Maybe cut back on gamma to reduce contrast, if this helps?
Good idea, I need to experiment a bit with the new setup.
