my telescope is 204mm F8.8 telescope.The filter is quantum 0.5A.
I would use a baader tz-4 magnification.
Where should the quantum be located in the telescope focus?
thank you.
Jong Ho
Quantum back focus?
- Bob Yoesle
- Has thanked: 541 times
- Been thanked: 811 times
Re: Quantum back focus?
See this link, which most importantly shows that the objective's focal plane is located ~ 93 mm behind the front of the TZ4 telecentric lens assembly - which should remain fixed, and the resultant focal plane lies 220 mm past the end of the TZ4.
The Quantum or (Solar Spectrum) etalon system can be placed anywhere in that 220 mm distance which will allow you to use a diagonal/eyepiece/camera system. Note that any focusing should take place after the TZ unit and likely will employ extension tubes depending on the proper configuration of the downstream components.
Bob
Bob
- mami813
- Has thanked: 151 times
- Been thanked: 236 times
hi,BobBob Yoesle wrote: ↑Mon Oct 31, 2022 1:59 pm See this link, which most importantly shows that the objective's focal plane is located ~ 93 mm behind the front of the TZ4 telecentric lens assembly - which should remain fixed, and the resultant focal plane lies 220 mm past the end of the TZ4.
Bob
Thanks for sharing the information.
Is it the same principle for Televue 4x powermate?
- Has thanked: 20828 times
- Been thanked: 10502 times
Who knows what the exact metrics are for the powermate, TV does not share them.
- Bob Yoesle
As Mark notes, who knows what the TeleVue Powermates are specified for? They only describe these as being developed for their more recent widefield eyepiece designs.
I should also note that the TZ2 and TZ4 were specifically designed for use with an 800 mm FL objective. However, Christian Viladrich at (F) shows the TZ4 does very well with almost any FL longer than ~ 450 mm.
The other suggestion is that BelOptik can design a custom made telecentric for your specific application. If you're handy with optical design software, you can likely also design your own using off-the-shelf lenses such as Peter Zetner's telecentric.
Note there is a great deal of similarity between a collimator lens system and a telecentric lens system ;-)
Bob
Bob
- mami813
Hello Bob.Bob Yoesle wrote: ↑Thu Nov 03, 2022 4:01 pm As Mark notes, who knows what the TeleVue Powermates are specified for? They only describe these as being developed for their more recent widefield eyepiece designs.
Bob
Thanks a lot for the information.
