http://brierleyhillsolar.blogspot.co.uk/ Solar images, a collection of all the most up to date live solar data on the web, imaging & processing tutorials - please take a look!
Nice,going to have to sort out adjustable slit for my SHG and have a go at this method.
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
1) you need a larger scope i use 60mm F12
2) you need ability to rotate rig to make tangent line to prom
3) grating should be 600lpmm or 1200lpmm max or else you get doppler distortion - SHG uses 2400lpmm
highfnum wrote: ↑Mon Nov 07, 2022 1:01 pm
1) you need a larger scope I use 60mm F12
Doesn't it also work better with a quite large slit (wider than the typical 10 micron SHG slit)?
Alun_H
my prom rig is separate from SHG
why?
Thank you for the information,I am thinking of using my rough n ready SHG which has a 1200/mm grating and will exchange the Alpy slit plate I have in place at the moment for a Surplus Shed adjustable slit. In regards to the telescope,I will use a 90mm f/10 achromat and have it mounted side by side along with the 72ED and Sol'Ex.
Alun
Lunt CaK B12 module
Sol'Ex SHG
