Animation of the "Sail" Filament from 11/3/2022
rigel123
Has thanked: 8536 times
Been thanked: 8764 times
Post by rigel123 »
The last animation from a great day for imaging yesterday. I caught this "Sail" Filament about 10 hours prior to it lifting off. Just a bit of activity of some fine tendrils within the body of the filament. I did both a natural with inverted proms and a totally inverted version. Each shows a little bit better details in different areas. I think my camera was slipping a bit as the cable started pulling on it as there is just a bit of rotation that processing didn't account for. Lunt LS60T DS, AS174MM and Meade 3X TeleXtender This is one hour in real time and the image has been rotated 90 degrees CW for viewing.
ImageSE Sail Prom Animation 11 3 2022 Natural by Rigel123, on Flickr
Inverted
ImageSE Sail Prom Animation 11 3 2022 Inverted by Rigel123, on Flickr
Link to Astrobin for full resolution
Has thanked: 17807 times
Been thanked: 16940 times
Re: Animation of the "Sail" Filament from 11/3/2022
Post by DeepSolar64 »
The spicule movement is very noticeable.
rigel123
Post by rigel123 »
DeepSolar64 wrote: Sat Nov 05, 2022 5:55 am The spicule movement is very noticeable.
They really dance at these higher frame rates I use to highlight the motion in the quiescent proms.
Has thanked: 17888 times
Been thanked: 8887 times
These are great! :bow :hamster: I didn't realise that it has lifted already, pity as it would have been a cracker on the limb ;)
The spicules on the disc are hard to see visually. The mottling is easy but resolving the mottles into the spicules is difficult. It takes both good seeing and high magnification on my SMII90. I rarely do it and never have cleanly. Double stack gives better contrast but unfortunately does not handle high magnification as well as single stack does with it's brighter image. It takes over 100x and DS gets dim over that.
rigel123
Post by rigel123 »
Thanks Alexandra, yeah the lift off was pretty impressive on GONG and was fairly rapid.
James, I typically see a hint of spicules on the screen at 3X but they really stand out in good seeing in animations.
Warren,
I need to concentrate more on the disc mottles. The spicule clusters. I find spicules easier to see and resolve on the limb in single stack above the limb of the photosphere bleeding through. They give an idea of the chromosphere's thickness though many, especially the macro-spicules stand well above the chromosphere proper. I do agree that animations are the best way to see and study spicules, on the disc and on the limb and you excel at that!
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Lovely animation Warren.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
SUPERB!!
Marios S.Ioannou
Sketcher/Visual Observer
rigel123
Post by rigel123 »
Thanks Maurits and Marios!
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Very well done Warren
arnedanielsen
Has thanked: 6276 times
Been thanked: 7288 times
Post by arnedanielsen »
Beautiful animation as always Warren!
Arne
Arne
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
Very nice, Warren.
rigel123
Post by rigel123 »
Thanks Stu
Has thanked: 20732 times
Been thanked: 10427 times
Excellent animation Warren!
rigel123
Post by rigel123 »
Thanks Mark!
