Today's SUN (20221105) | NEW BIG AR
pedro
Has thanked: 14 times
Been thanked: 6685 times
Post by pedro »
WEB LINK:
http://pedroreastrophotography.com/sun_ ... 22-11.html
Solar imaging session (20221105) | Pedro RE'
TELEVUE NP127 F/5.2 | LUNT152 F/6
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
SUN (20221105) WL. LUNT152 F/6, B3400, X4 Powermate, ZWO ASI 174MM
SUN (20221105) WL. LUNT152 F/6, X2 Zeiss Abbe' Barlow, PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (20221105) H-alpha. LUNT152 F/6, B3400, X2 Zeiss Abbe' Barlow, PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (20221105) H-alpha (08:00 UTC). TV NP127 F/5.2, DS SM90II/SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5
SUN (20221105) H-alpha (08:00 UTC). TV NP127 F/5.2, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M
SUN (20221105) WL, CaK & H-alpha (08:00 UTC). TV NP127 F/5.2, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5M
rigel123
Has thanked: 8542 times
Been thanked: 8772 times
Re: Today's SUN (20221105) | NEW BIG AR
Post by rigel123 »
Nice complex of spots rounding the bend and great shots Pedro!
Has thanked: 17813 times
Been thanked: 16950 times
Post by DeepSolar64 »
Pedro,
These are all really nice. Which do you prefer, the 4x TV PowerMate or the 2x Zeiss Abbe' barlow? You appear to be getting in just as close and with as much detail using the barlow as you are using the PowerMate.
A friend of mine won't even consider a barlow against a PowerMate. Are they that much difference between them? Especially if a high quality barlow is used like your Zeiss or a TeleVue barlow. I think you have the TV BIG barlow too!?
I can tell little difference if any between the quality of your Zeiss Vs the TV PowerMate. Both are excellent. I usually use my Meade Coronado CeMax or Celestron Ultima 2x barlows. They seem to do fine.
The biggest difference I see between the PowerMates and the typical barlow is magnification. Most barlows are 2x. PowerMates can be purchased to 5x.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Great shots Pedro.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Great work!
Marios S.Ioannou
Sketcher/Visual Observer
pedro
Post by pedro »
Thanks guys
James, I use powermates most of the time (X4 & X5). These are great and there is no big difference between good quality barlows and powermates. The ASI174MM is better for HR images (it records more images/s). The Zeiss Abbe' Barlow is the best in the market with a high price tag
At the end of the day it all depends on seeing
Has thanked: 17925 times
Been thanked: 8891 times
Wow!! this is a big pair :bow :hamster:
pedro
Post by pedro »
Thanks, it's really BIG
pedro wrote: Sun Nov 06, 2022 10:28 am Thanks guys
James, I use powermates most of the time (X4 & X5). These are great and there is no bif difference between barlows and powermates. The ASI174MM is better for HR images (it records more images/s). The Zeiss Abbe' Barlow is the best in the market with a high price tag
No big difference. Have you seen any barlows with more than 2x power? I have seen a few 2.5x but never more, at least that I can remember. The magnification range alone makes the PowerMates very useful. Still, my barlows perform well. What's the design difference between the PowerMates Vs the typical barlow? Is the PowerMate an apochromatic barlow?
Seeing always rules...
pedro
Post by pedro »
I do not see a big difference if you use good quality barlows and powermates. I use a TV BIG barlow and a Zeiss Abbe' most of the times and TV X4 & X5 TV powermates
DeepSolar64 wrote: Sun Nov 06, 2022 3:04 pm
Thanks Pedro. I've always wondered what the difference is between the two.
arnedanielsen
Has thanked: 6276 times
Been thanked: 7294 times
Post by arnedanielsen »
Fantastic collection Pedro!
Thanks for sharing,
Arne
Arne
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Great images, Pedro. The weather here is awful so no chance of seeing the new sunspots myself for a while.
pedro
Post by pedro »
Thanks again guys
raining here as well
KMH
Has thanked: 657 times
Been thanked: 764 times
Post by KMH »
Pedro,
First - great pictures as usual!
Also, I'm wondering if you could please comment on your experience with the ASI174 vs the Grasshopper. I currently have that same Grasshopper model and am thinking about getting an ASI174, mainly for the higher frame rate.
Do you image at 8 bit, or higher? Does the ASI174 framerate drop off a lot at higher bit depth (such as "16 bit" mode in Firecapture)?
I'm also thinking about the FLIR Blackfly BFS-U3-28S5M-C (IMX421), which has essentially the same pixel/sensor size as that Grasshopper but a CMOS sensor with 130 fps. Do you have any knowledge of that?
Thanks very much for your time!
Kevin
Has thanked: 20738 times
Been thanked: 10439 times
Lovey set of images Pedro!
Kevin, do you have any other cameras? The 174 with its large pixels is only really suitable for long focal length applications. I have the FLIR version of the 174 and it drops frames in FC when I run in 16 bit. Whilst I don't have personal experiernce of the 421the specs of it look good.
KMH
Post by KMH »
marktownley wrote: Wed Dec 21, 2022 7:07 am Lovey set of images Pedro!
Mark,
Thanks for the feedback - your advice is appreciated! For solar I have only the Grasshopper ICX674. I like it a lot but would like to try something with a higher frame rate. This initially led me to consider the Blackfly IMX421 (with essentially the same pixel/sensor size). But the 174 also seems like a reasonable possibility. I almost always image with a 2.5x or 4x Powermate and Halpha (Lunt f/7 THa100), so the 174 pixel size seems like it would work pretty well, maybe even a bit better than the 421(??).
I'm guessing the reason you chose the FLIR version of the 174 is so you didn't have to use USB power for the camera??
Kevin
pedro
Post by pedro »
Thanks Kevin
I only use the ASI174MM for HR (X4, X5 powermates and Daystar Quark). The bigger pixels are great for the long focal lengths. I always image in 8Bits, As Mark mentioned he 174 and it drops frames in FC when I run in 16 bits. Most of the times I use the grasshoppers, CCDs and much better than CMOS.
Hope this helps
KMH
Post by KMH »
Pedro,
Thanks for your comments! If I could trouble you with one more question, can you elaborate on your comment of CCD vs CMOS?
Thanks again!
Kevin
pedro
Post by pedro »
Hi Kevin
I prefer CCD versus CMOS. The former have better dynamics and less noise. You can find lots on info on the net regarding CCD versus CMOS
