Solar guiding using ordinary guide scope
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
Something that we have been wanting to try for some time is to guide using our night time guide scope, so we made a white light filter for it.
The software we used for the guiding is the same as we use for capturing which is ZWO ASICAP. It allows you to guide on a planet which in this case, is the sun. You can do it from the primary camera provided it is full disk, but it will adversely affect the capture rate. Instead we split the guiding and capturing to two separate computers, the primary capture computer has just got the main camera attached at USB3.0. The guiding computer is running the mount via KStars / Ekos and a second instance of ASICAP doing the guiding via the guide camera's ST4 port.
Even though our mount is reasonably polar aligned, there is normally some drift over time. This set up held the image central for a full hour but unfortunately the animation is only 30 minutes as the disk space had run out!
Guide scope set up The resultant animation
Clare & Peter
- Has thanked: 42 times
- Been thanked: 1487 times
Re: Solar guiding using ordinary guide scope
That looks really good. Does it really slow down the capture to have guiding and capture on the same computer? The guide camera runs on USB 2.0 and you could do binning and even limit the frame rate. You don't need very high resolution or a very fast update. You might be able to run two separate instances of the same program or use different different programs.
- Has thanked: 20424 times
- Been thanked: 10242 times
Good result!
- Averton
Yes it is quite possible to do the lot from a single computer and ASICAP is happy to have a number of instances open at the same time. Although doing it this way doesn't hugely slow the primary capture rate, it definitely have some effect. As our capture camera is 6MP at 60FPS, we are pushing the 5Gb/s limit of USB3.0 and due to the amount of data we have to save to an external USB3.0 SSD, it works best to use the second computer for the guiding and mount control.thesmiths wrote: ↑Thu Nov 10, 2022 5:31 pm That looks really good. Does it really slow down the capture to have guiding and capture on the same computer? The guide camera runs on USB 2.0 and you could do binning and even limit the frame rate. You don't need very high resolution or a very fast update. You might be able to run two separate instances of the same program or use different different programs.
Clare & Peter
- Averton
It's possible every computer is different and it might depend on the age and speed of the hardware. But in general, each USB 3.0 interface has it's own bandwidth allocated (as long as it's a motherboard port and not a hub). Also, for guiding, you don't need to write any data. From my experience, I can run a ZWO USB 3.0 camera at full FPS and connect the mount using EQMOD and an auto focuser via the capture software (both USB 2.0) and all seems to work ok on the same computer.
By the way, you can generally get faster SSD write speeds via a USB-C port than USB 3.0, and even faster using an internal NVMe SSD. But I have found in general, the data speed is limited by the camera itself, not the computer or the USB interfaces.
Also worth noting, I would try to properly use the VRAM feature of the capture software (both FireCapture and SharpCap [paid version] have this; I suspect ASICAP does not). I found this feature is quite critical for getting glitch free capture of very high speed file capture. What the program does is reserve a percentage of the computer's DRAM as a temporary disk (typically say 8GB out of 16GB). It then stores the data there before eventually writing to the SSD. The VRAM is probably 100x faster than the SSD. But you have to be careful then about the file size not exceeding by much the VRAM size that's been allocated, and also I found it's best to wait a few seconds before starting a new file capture to allow the capture program to write the data and empty the VRAM.
- Averton
Thanks. The VRAM option isn't implemented in ASICAP but ASICAP runs the best under Linux, so that's what we use. We'll give it another run (if we ever see the sun again [worst year in history for bad weather on the east coast of Australia]) with everything running on one computer and see how it goes.thesmiths wrote: ↑Fri Nov 11, 2022 12:31 pmIt's possible every computer is different and it might depend on the age and speed of the hardware. But in general, each USB 3.0 interface has it's own bandwidth allocated (as long as it's a motherboard port and not a hub). Also, for guiding, you don't need to write any data. From my experience, I can run a ZWO USB 3.0 camera at full FPS and connect the mount using EQMOD and an auto focuser via the capture software (both USB 2.0) and all seems to work ok on the same computer.
Clare & Peter
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Veru interesting. I never tried ASZiCAP before.
I think Firecapture may have guiding functionality, and GreatAttractor (Filip) did use specialised solar tracking software for his prom animations recently.
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 753 times
I use Vidoxide, see this video for a short demo. Though I haven't created a Windows build yet (had some problems with the Spinnaker camera driver not working, unlike on Linux), in principle the program should work with any ASCOM-visible mount, and supports ZWO cameras as well.
But since FireCapture has the same auto-guiding feature and is better-tested, it's probably simpler to just use that.
- Averton
Yes FireCapture does have guiding and would work just the same in our set up. We just use ASICAP because it works best with Linux.
Clare & Peter
- Rob63
- Has thanked: 573 times
- Been thanked: 591 times
That is looking great Filip, I will definitely be trying it when you have a windows build available.GreatAttractor wrote: ↑Sat Nov 12, 2022 5:18 pm I use Vidoxide, see this video for a short demo. Though I haven't created a Windows build yet (had some problems with the Spinnaker camera driver not working, unlike on Linux), in principle the program should work with any ASCOM-visible mount, and supports ZWO cameras as well.
Quark Chromosphere, Lunt LS60MT DS, Lunt Ca-K B1200 module, Baader herschel wedge
Sky-Watcher ED120 & ED80, StellaLyra 8" CC
Sky-Watcher EQ6R-Pro, ZWO AM5
ZWO ASI120MM, ASI174MM, ASI290MM, ASI1600MM
- Radon86
Hi Clare and Peter,
I would be grateful if you can post details (as much as you wish) on how you mounted the guidescope, as I have not seen it before). It looks like a M5 or M6 screw fits onto the main tube rings, and there is a small circular tube spacer which fits over the screw hole on the rings. Then there is an improvised type of aluminium or steel dovetail which is clamped on by the guidescope/guidescope tube ring mounting.
[Even though our mount is reasonably polar aligned, there is normally some drift over time. This set up held the image central for a full hour but unfortunately the animation is only 30 minutes as the disk space had run out!] - you could polar align the previous night and let the mount settle there (only possible if good weather or high pressure) or you are willing to cover up if there is rain or unstable weather. Or use Firecapture or other guiding software which you have used here.
Thanks,
Magnus
Thanks,
Magnus
- Radon86
Hi Filip,Rob63 wrote: ↑Fri Jul 14, 2023 3:45 pmThat is looking great Filip, I will definitely be trying it when you have a windows build available.GreatAttractor wrote: ↑Sat Nov 12, 2022 5:18 pm I use Vidoxide, see this video for a short demo. Though I haven't created a Windows build yet (had some problems with the Spinnaker camera driver not working, unlike on Linux), in principle the program should work with any ASCOM-visible mount, and supports ZWO cameras as well.
I checked your github/vidoxide software, and it says there is a Windows build available now. Is this correct ? I would like to try your vidoxide software if it is. Or maybe I can adapt it or build upon it ?!
Magnus
- GreatAttractor
No, I haven't published any binaries. But compiling from sources is straightforward, I'd be happy to assist.
- Averton
Hi Magnus,Radon86 wrote: ↑Sun Jul 16, 2023 6:02 am Hi Clare and Peter,
Thanks,
Magnus
You have sussed out the set up fairly well. Only the bolts used are 1/4" x 20 as the tube rings for the scope have 1/4"x20 holes already there for camera mounting. The tubular spacer is 16mm diameter, 1mm wall thickness aluminium tubing that we bought from our local hardware store in Australia. The long section is not a dovetail, it is simply 12mm hollow aluminium square section with 1mm wall thickness, again from the hardware store, that has two holes tapped 1/4" x 20 which then has two bolts screwed through it to hold the guide scope mounting. The spacing of those two holes is to match the spacing of our other refractor, which is a 72ED. The guide scope is actually a finder scope with the rear diagonal and eyepiece removed and a 3D printed adapter to accept the ASI120MM guide camera. The guide scope holder with its rings and base are actually made from laser cut plywood parts. Each part is 3 laminations of 3mm poplar plywood which cut on our laser cutter. Attached is a picture of the guide scope arrangement before painting, fitted on the 72ED. Hopefully this will clarify the construction.
What you suggest regarding polar alignment is quite true, but we find that with our marked out location for the mount plus the guiding its more than enough for a couple of hours of time lapse captures.
Hope this is of help.
Regards
Clare & Peter
Clare & Peter
Thanks for the post; I am trying to do exactly the same. Would you post some details about how you connected your setup ?
ie: I see you have 2 cables coming out of your guiding camera but the guiding happens on your guiding laptop.
I was picturing, the camera being connected to your laptop with a USB-C - USB-C or USB-A cable and the guiding instructions
going a USB cable from your laptop to the mount via a USB-to-ST4 cable.
The picture of your setup suggests otherwise.
Would you mind explaining further ?
Thank you,
phil
Thank you,
phil
