Double stack Ca K / October 6 / comparing telecentric mount or not
- Been thanked: 2713 times
Here are some old images taken in a test session comparing telecentric and not telecentric mounts for a double stack Ca K configuration.
It started with a FD image suffering from seeing effect due to the low elevation of the Sun :
http://astrosurf.com/viladrich/astro/so ... SI1600.jpg
The same with prominences (and a lot of glare ...) :
http://astrosurf.com/viladrich/astro/so ... 00-ddp.jpg
But my main objective was to compare my usual setup using Baader FFC as a Barlow lens, and the Airylab f/27 telecentric I use for Ha observation with my Celestron 8 EdgeHD. A double stack combination (Alluxa 0.37 nm + Alluxa 1 A Ca K filters) was used.
Measurements with the SHG Sol'Ex show there was indeed a small advantage to the telecentric combination :
- the bandpass of the combination at 10% peak transmission is 3.3 A in a telecentric beam,
- while it is in the range of 4.5 A with the FFC.
This is because the 0.37 nm filter needs to be tilted to be on Ca K.
In real life, the difference is very small.
With the FFC :
http://astrosurf.com/viladrich/astro/so ... AR3116.jpg
With the telecentric :
http://astrosurf.com/viladrich/astro/so ... entric.jpg
Christian
With the FFC :
Christian
- Has thanked: 4213 times
- Been thanked: 3818 times
Re: Double stack Ca K / October 6 / comparing telecentric mount or not
Great work.
- Has thanked: 9145 times
- Been thanked: 6025 times
Hi Christian: beautiful images. Interesting comparison: hard for me to see any differences unless I see the images side by side, but good to know. The 2.7x Airylab telecentric is very good quality.
- Been thanked: 10247 times
Excellent comparison Christian. It is close, but like Franco says good to know the Airylab telecentric is good, which mirrors my findings with CaK.
Also interesting about the measured bandpass of the filter in the FFC / Airlylab optical trains.
- Has thanked: 2978 times
- Been thanked: 2082 times
Hi Christian,
thx for the comparison, to me the closeup image with the FFC is clearly crisper then the other one for whatever reasons.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- nicspenceryork
- Has thanked: 5856 times
- Been thanked: 1257 times
Gorgeous images and plenty for me to learn from,
Thanks
Nic
Thanks
Nic
- Has thanked: 8418 times
- Been thanked: 8163 times
Thank you, Christian. Great images and nice comparison. If only I could get anywhere near this quality
- Been thanked: 8792 times
All of these are absolutely terrific but I do think I prefer the FFC image, no idea why but I just do
Thanks to all !
Franco and Mark, indeed it was following your various comments and discussions that I finally decided to test the Airlab telecentric in Ca K :-)
Denis, yes the version with the FFC is a bit crisper. This may be why you prefer it Alexandra.
At this stage, there are three possible (and not exclusive ...) explanations :
- seeing was better when the image with the FFC was done,
- in Ca K, the optical quality of the FFC is a bit better than the optical quality of the telecentric,
- this is the "normal" results of a narrower bandpass. Indeed, in CaK when we narrow the bandpass, we sample a higher layer of the chromosphere. And because the magnetic lines are "divergent", the details become fuzzier and larger when observed with a smaller bandpass.
And now the Sun is too low for any more testing....
Christian
Christian
- Been thanked: 4787 times
That's a wonderful Calcium image Christian.
Interesting the exposure / gain were the same for both images. Did you adjust spacing with the FFC to get the same image scale?
Thanks Maurits :-)
Mark, yes and no. By chance, in just happens that I have the same image scale with both setup.
Thanks Christian.christian viladrich wrote: ↑Wed Nov 23, 2022 8:58 pm Measurements with the SHG Sol'Ex show there was indeed a small advantage to the telecentric combination :
Any idea, even mathematically, how the filters would perform in a collimated beam?
Basically, there could be a "sweet spot", but some calculation is need to evaluate it.marktownley wrote: ↑Sat Nov 26, 2022 6:39 am
Thanks Christian.
I am developping a little piece of software to answer this kind of question. Still, the project is a bit on hold since I am busy on other stuff.
I look forward to it Christian!
