First ligth with etalons Quark combo and Lunt LS40.
- Has thanked: 4379 times
- Been thanked: 3976 times
I finished this build this morning and was lucky enough to get about an hour of sun. However, the conditions were very poor.
- a1.jpg (1.12 MiB) Viewed 575 times
- a2.jpg (1.27 MiB) Viewed 575 times
- a3.jpg (638.09 KiB) Viewed 575 times
- a4.jpg (437.82 KiB) Viewed 575 times
- AR150/F8,TZ3x,Quark+LS40+IMX533 BIN3
- s1c.jpg (945.2 KiB) Viewed 575 times
- s2c.jpg (1002.7 KiB) Viewed 575 times
- s3.jpg (693.85 KiB) Viewed 575 times
- s4.jpg (1.14 MiB) Viewed 575 times
- s5.jpg (855.06 KiB) Viewed 575 times
- s6.jpg (1.32 MiB) Viewed 575 times
Re: First ligth with etalons Quark combo and Lunt LS40.
Glad to see you squeezing the last out of the winter Sun
That's a really great setup Pupak, with beautiful results.
- Been thanked: 10487 times
Very good, but try it without the additional blocker.
I don't use two blocking filters. It's just Quark blocking filter. He is not in front, but behind Quark.
- Has thanked: 17853 times
- Been thanked: 16995 times
I can tell how low the sun is by the low angle of your scope. The sun must be just a few degrees above the horizon.
Beautiful surroundings Pupak!!
You should use it infront of your Quark, you risk damaging the Quark.
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
Great set up Pupak. Nice machining work on the etalon housing and the adapters.
Considering poor conditions the set up is already showing great potential.
What are the adapters between the draw tube on the Quark and the nose piece of the Player One camera and what are their purpose?
It seems to create a lot of back focus between the Quark and the camera. Is this needed?
Clare & Peter
- Has thanked: 9319 times
- Been thanked: 6157 times
Beautiful setup, Pupak. Can’t wait to see results in good weather !
At the input is a DERF 180mm, then a 2" H-a 35nm, behind it is a TZ3x telecentric element, a Lunt LS40 etalon, a Quark and at the end a blocking fitr. I don't see the slightest reason why the Quark should be at risk of damage.marktownley wrote: ↑Sun Nov 27, 2022 9:15 amYou should use it infront of your Quark, you risk damaging the Quark.
The TZ3x has a large back focus (250mm), which is why the extension tube is in front of the camera.Averton wrote: ↑Sun Nov 27, 2022 10:27 am Great set up Pupak. Nice machining work on the etalon housing and the adapters.
- Averton
Thanks.pupak wrote: ↑Sun Nov 27, 2022 11:57 amThe TZ3x has a large back focus (250mm), which is why the extension tube is in front of the camera.Averton wrote: ↑Sun Nov 27, 2022 10:27 am Great set up Pupak. Nice machining work on the etalon housing and the adapters.
Clare & Peter
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Great first results, well done
Pedro Re'
