80 minute animation from yesterday Up Over uʍop ɹǝpun
- Peterm
- Has thanked: 1733 times
- Been thanked: 1488 times
Howdy,
Finally have some Sun but accompanied by Westerly winds on our balcony. Here I present 80 minutes of animation I captured yesterday morning UT 2022/11/24 22:26 to 23:47
The animation is rotated 90deg clockwise with East towards the top. The monochrome image below is more or less correct orientation. I used my 5X Powermate with my 80mm single stacked Lunt and a ZWO432MM.
please click the image to view on my Astrobin page.
I should have mentioned and thought you may like to know how I control everything from indoors. The black "snake" has several 10m USB3 active cables that control the AVX mount through CPWI, the ZWO camera through SharpCap Pro4 and the Solar Scintillation monitor. A USB3 hub at the Celestron AVX connects the Hinode Solar Guider that is then connected to the ST4 port. The Moonlite DC focuser is controlled by a cable that goes back inside to a FCUSB and I use Focus Pal software for focussing. My laptop is plugged into a docking station that gives me access to 4USB3 ports at the rear. I also use my 40inch 4K TV as a 2nd monitor. Sure, it's old school cables but rarely if ever gives me any hassles. It gets very hot out on the balcony in summer, so I first protect me by being indoors and then try to "protect" the camera, mount, hand controller etc with windshield cover material as you can see in the pic.
One other thing is having a spare Celestron hand controller that I can plug into an AVX Auxillary port at the mount, this allows me to make any small changes after slewing the mount to centre the Sun for Polar alignment.
I have a long way to go in my Solar imaging journey but animations are what really excite me about Solar imaging, you can see a collection on my Astrobin page.
Thanks indeed for looking.
Best,
Peter
Gold Coast, Australia
Best,
Peter
- rotate08_31_55_lapl5_ap2329_out-DeNoiseAI-low-light.jpg (125.54 KiB) Viewed 620 times
- col082640-DeNoiseAI-low-light.jpg (127.61 KiB) Viewed 620 times
- 20221125_092158.jpg (192.17 KiB) Viewed 620 times
BOSS team: www.bosssupernova.com
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
Re: 80 minute animation from yesterday Up Over uʍop ɹǝpun
Some nice images and animation Peter.
Lovely situation by the water too. That must help your local seeing conditions.
Whenever I see an imaging set-up I always look around for solar heated objects which might affect local seeing conditions.
There seems to be a dark box to the right which might benefit from a [temporary] white cover.
I can recommend white, lightweight tarpaulins as [temporary] thermal shades/covers.
This material reflects heat and remains at ambient temperature. Not ideal when it is windy.
Easily cut to size with scissors and dirt cheap too. Though relatively short lived if you have any hope of waterproofing.
The table, chairs and balcony rail have black metal frames. It might be worth moving the chairs away from the vicinity.
Temporarily cover the balcony rail and table with white material held by clothes pegs.
You only need to do this once. Just to see if it helps your local seeing.
An inexpensive "pistol" style thermometer is a handy tool for checking everything around the observing/imaging site.
Obsessive-compulsive behaviour, I know, but worth considering while you wait for a capture to end.
We often spend a fortune on equipment in trying to get the last bit of fine detail.
Then completely ignore the "red hot" objects around us. As a potential loss of fine detail due to convection currents.
- Has thanked: 4219 times
- Been thanked: 3818 times
Fantastic.
- Has thanked: 9145 times
- Been thanked: 6027 times
Very nice animation, pics and beautiful place to image from, Peter.
- Been thanked: 4787 times
What a beautiful place to image Peter, water helps to create a better seeing.
Nice images and animation.
- Been thanked: 10248 times
Nice images and animation Peter! Lovely view on that balcony too!
- Has thanked: 6181 times
- Been thanked: 7142 times
- Radon86
- Has thanked: 745 times
- Been thanked: 660 times
Hello Peter,
Thanks for your brilliant post and animation.
I should add that I tend not to setup my solar when it is too hot as it can be too difficult to concentrate in very hot weather and I do not have solutions to protect equipment apart from a cardboard shade on the telescope tube. I can try your solutions.
May I add a suggestion to your video?
So to know when the end is present? To introduce a delay so you know a new loop is occurring.
Also, I do not see much point in the disc animation as that is not what you are imaging? Better to mask this out entirely. Then move the main subject into the centre.
How did you get so little noise, and such a dark background?
Superb!
Magnus
Superb!
Magnus
- Has thanked: 17581 times
- Been thanked: 16697 times
What a beautiful observing site. Water nearby should help your local seeing. I hope to get an AVX someday myself.
Nice images and I now know where Summer has gone!
- Peterm
Thanks so much for your reply Rusted,Rusted wrote: ↑Sat Nov 26, 2022 6:07 am Some nice images and animation Peter.
You have touched on some thoughts I had. The chairs and box are all plastic with the timber bar table. I will see if moving things away from the scope does have a noticeable effect. The rail being metal is a good 4 feet way but could be a source of heat infront of the scope, so you have given me some ideas. I try to negate the effect of concrete tiles and walls around me by starting my imaging with a sun 10 degrees above the horizon so typically in Summer 530am to 930am, after that is something I have rarely done. Thanks to Covid we have a pistol style thermometer that can now be put to interesting use, had never thought of measuring the temperature of the scope etc.
- Peterm
Thank you so much!Radon86 wrote: ↑Sat Nov 26, 2022 5:16 pm Hello Peter,
*This is a great suggestion Magnus. I can change the speed of the animation in GIMP but I will need to read up on GIMP and see how put a delay at the start, any ideas?
*Fair comment, this is something I try to present when I have enough time to process, so the way I am going of late is to present both the disk and proms. Often this has led to some surprising flares and other activity on the disk.
*I do a lot of manipulation using ImPPG and then run the final images through Topaz Denoise.
Superb!
Magnus
- Has thanked: 8418 times
- Been thanked: 8165 times
Beautiful animation, Peter. I’m so jealous of your balcony view. It looks idyllic.
- Peterm
Thank you Stu, we are very lucky to live where do. The Solar viewing/imaging benefits came as an extra bonus!
- Been thanked: 8793 times
Superb animation and pictures and I really enjoyed the view, wow, you are on holiday permanently
- Peterm
Well thank you very much Alexandra and all who have viewed. I was rather chuffed to see my animation in the SPOD light! Big thanks! The rest of this week is out due to days of foul weather we are starting to experience.
