Baader D-ERF or Lunt ERF?
- OlegLviv
- Has thanked: 918 times
- Been thanked: 946 times
Hello friends! I have a plan in a future modification my 152/f5.9 telescope and wants will buy ERF filter and put inside ERF because with my modification can't screw a 2 inch filter (Baader 35nm or UV/IR CUT) in front of the etalon and ERF full aperture ist expensive for me....
Therefore, I have a question, what is the minimum erf size of 75 mm or 90 mm or 100 mm that can be installed in the diaphragm of the refractor?
And second question about brands ERF? (baader vs lunt)
Thank you!
Thank you!
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
- Has thanked: 4379 times
- Been thanked: 3976 times
Re: Baader D-ERF or Lunt ERF?
If my information is correct, D-ERF contains dielectric reflective layers and hardly absorbs heat. Lunt's ERF is red glass with an IR coating so it absorbs more heat. I know two colleagues who have been running an AR150 for a long time with a 53mm ERF from Lunt in a combination of 2" H-a 35nm. This is a photographic mode, not a visual one.
I would be afraid of it myself, but they have been running it that way for several years and have had no problem. It is important to have the correct slope of the filter to avoid reflections.
- Has thanked: 20818 times
- Been thanked: 10487 times
For a refractor that size and that fast you should mount the largest one you afford internally, the bigger the better!
- Been thanked: 2725 times
Regarding optical quality, my 160 mm D-ERF was measured to lamda/9.6, which is excellent :
http://astrosurf.com/viladrich/astro/in ... /tests.htm
Of course, it comes to a cost.
I haven't seen any measurement for Lunt ERF filters.
- OlegLviv
Thank you for answers!
Tell me about PST etalon all pst etalons have 1A or Is it possible to have less?
I bought 152/f5.9 If will be buy Baader Glasspathcorrector 1:1.7 for Baader and put front my pst etalon will be F10 and its good result? (PST MOD 2)
Thank you!
Thank you!
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
I think it will work well!
- OlegLviv
I mean like this a photo 1.25 but 1.7!
- 42518260260_acd1700537_k.jpg (431.29 KiB) Viewed 2135 times
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
As with all etalons there is much variance between them, some are good, some not so good. It's a case of either dropping lucky when you get one or buying several before you get a good one. I did the latter.
- OlegLviv
I remember i have Powermate 2x 2.0 can use in a front etalon PST and will be have f11?marktownley wrote: ↑Wed Nov 30, 2022 6:43 am As with all etalons there is much variance between them, some are good, some not so good. It's a case of either dropping lucky when you get one or buying several before you get a good one. I did the latter.
Its tru that PST etalon USA better than PST etalon Made in Mexico?
Thank you!
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
As said by Mark, there is a lot of variance in PST etalons.
I measured an excellent one at 0.34 A FWHM. His owner told me it was an "old generation" PST.
The other one was at 0.60 A FWHM. Not bad.
These are only two measurements. This is far from a statistics.
http://astrosurf.com/viladrich/astro/in ... lters.html
- OlegLviv
Tell me about F with Etalon!
TS 152/5.9+Baader Glasspathcorrector 1.25=F7.4+Powermate 2.5x=F18.5 ist less for air space etalon???????? Lunt 50 mod!
TS 152/5.9+Powermate 2x 2.0=F11.8 +Powermate 2.5x=F29.6 its normal for air space etalon???? PST Stage 2!
Is my theory true?
Does this apply only to telecentric?
Because as for me Lunt 50 F7 will be better mod than Pst Stage 2 because F7 not F10 ?
Thank you!
Is my theory true?
Thank you!
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
I'm afraid it won't work for you with the 1.25 focal shift. This is an optical element that only shifts the focus but does not change the beam angle. It's not Barlow. It behaves similarly to a pair of lenses in the etalon. These will also shift the focus but maintain the beam angle. Correct positioning in the optical path is important for the Lunt etalon. F is not so critical.
Today I tried the AR150/F5.9 combination with the LS80 etalon, TV5x Powermate (F30) and Quark combo. Photos are in the Solarchat section. The sweet spot seems acceptable.
