November 29 2022 540nm Visual Session.
- Has thanked: 17925 times
- Been thanked: 17066 times
Today I did both a visual and imaging session using the Coronado SolarMax II 90 in SS ( 656.28nm ) and the Astro-Tech AT72EDII at 540nm. The Coronado is used for imaging and I will post those images in a separate post when I get them finished in editing/processing and the Astro-Tech was used for visual photosphere. I will post that part of the session here. The temperature was 54F ( 12.2C ) and the skies are mostly clear. The seeing is fair/average.
Astro-Tech AT72EDII w/Altair wedge and 540nm filter. 21.5x and 43x ( WL )
Today I can only see three regions on the 540nm photosphere. A patch of faculae is seen neat the NE limb. AR13152 is now in the NW quadrant and shows three small spots in a line to my small refractor. The easternmost spot is the largest. AR13151 is visible as a patch of faculae very near the SW limb. SDO HMI images show a small spot there but I did not see it. The fine granulation of the photosphere is visible.
The Ha imaging part will come later. Probably late after work.
- Has thanked: 20910 times
- Been thanked: 10568 times
Re: November 29 2022 540nm Visual Session.
Thanks for the report James, I'm glad you got some sun. The fog persists here for the foreseeable. Winter is coming!
- rigel123
- Has thanked: 8628 times
- Been thanked: 8865 times
That is one quiet disk!
- Been thanked: 5010 times
James:
Thanks for the report, no Sun at my place just clouds.
Regards.
Regards.
- Has thanked: 2497 times
- Been thanked: 4920 times
Welcome. It's raining here as I type this.
- Has thanked: 18062 times
- Been thanked: 8920 times
A very quiet disc, I look forward to the Halpha
Could you have a quick look at this post James viewtopic.php?p=363900#p363900 I'm not sure which version of the 90 you own but you might be able to offer some help.
Alexandra,
I chimed in on the SMIII90 post. Stephen is certainly more familiar with that model more than I am. They are certainly a much more attractive instrument than mine. Theoretically they are better due to having completely external etalons but one thing I have never liked about Coronado is the center foot within the etalons. Refractors should NEVER have a central obstruction. That's where their sharpest performance is. Isn't the PST Coronado's only exception. I think they are unobstructed.
Yes, the PST is unobstructed but the double stack unit isn't
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Thanks for your report James, nothing but rain here in Brisbane.
It's sunny here today and the Sun is showing two new active regions near the eastern limb!
