Chapter 2 of Idea of a Cooling Aid assistance for cameras
- Has thanked: 9710 times
- Been thanked: 5764 times
NO Sun imaging as the Pam trees are paying their toll ...
Here is version 2 of the cooling assistance for 62mm Ø ZWO cameras.
At the moment heating up the camera with everything mounted but 50mm fan not running. Waiting that the temperature stabilizes. BTW they need quite a long time to get to its maximum temperature.
In about 1-2 hours I will report if succesful or not ...
ZWO ASI 120MM running at 173.4fps with a roi of 320x240
Re: Chapter 2 of Idea of a Cooling Aid assistance for cameras
OK, after nearly one hour of blowing the air into the manifold not much happened and so I decalre this test #! as a FAIL
I changed now the fan direction and I am sucking the air through the manifold. Let us what happens.
- Has thanked: 20779 times
- Been thanked: 10456 times
You're having fun with your 3D printing Rainer. I enjoy watching your experiments.
Second test with sucking fan
FAIL
OK, this manifold design goes into the trash bin and the one shown in Martin's post, hetsink, will be redesigned for a 50mm fan.
FAIL
Hi Mark,marktownley wrote: ↑Wed Dec 07, 2022 9:14 pm You're having fun with your 3D printing Rainer. I enjoy watching your experiments.
Yes it is fun and apart from that learning new design tricks and so on.
- Has thanked: 612 times
- Been thanked: 403 times
If i can find a fan that can work by USB and it has exactly same spacing of screws as on the back of those ZWO non cooled cameras i will give it a try, i don't have any 3D printers or DIY tools.
OK, using the Camera ribs with my badly designed manifold had no success neither blowing or sucking.
Here is another Heatsink design with a 50mm fan. On the right you see the 40mm fan version.
Cooling efficiency is at the moment from 30°C down to 25°C at an ambient temperature of around 20.5°C.
Will it cool better bu sucking the air ? Need to test it.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Hi Rainer, I found the best setup for cooling on my original camera cooler was a fan blowing into the heatsink and using a 12volt Peltier module at 5 volts. Running a 12 volt Peltier at 12 volts needs a large heatsink to dissipate all that heat.
I found that passive cooling did not work as you need to chill the camera casing.
I've been doing more testing on my phone cooler mod.
I can produce condensation on the Aluminium plate after about 30 mins on my test bench, but not outside in the sun.
Insulating the camera body might be an option as isolating the camera body from the ambient heat outside, means that the cooling module is drawing heat only from the camera body and not the ambient air around the camera.
I'll continue my experiments in a few days time as we are spending quality time with our two granddaughters as they stay over with us for a few days during the school holidays.
Martin
Martin
Hi Martin,
There are two ways to do things
One is the simple and the other one is the complicated
Isolating the whole camera body could bring, at least I think, the problem of icing the chip inside the chamber ... ¿? as this cameras do not have a sealed chamber nor desiccant inside the body.
Worth a test
Worth a test
This is with the phone cooler ?I can produce condensation on the Aluminium plate after about 30 mins ...
- Martin_S
Hi Rainer, it sure is. Even with my Peltier cooler I never got the camera cold enough to cause condensation in the outside heat. It might be a different scenario in colder climates. Where I am in Brisbane , Australia, the daytime temperature rarely drops below 12 degree's Celsius, so internal condensation may not be an issue.
I can now get condensation after 15 mins inside on my desk, if you look carefully you can see where I have wiped it off.
ZWO use a combination of 2 Peltier modules in their cooled cameras.
Martin
Martin
So they do have a peltier element installed ? Interesting ...
- Martin_S
Hi Rainer, here's another image of my phone cooler that I use on my ASI cameras this was taken around 7am while I was waiting for a gap in the clouds.
- 20230115_070117.jpg (68.66 KiB) Viewed 1617 times
Interesting thanks Martin, just found them on Amazon over here.
- Martin_S
Hi Mark, I've been testing mine in the Australian sun all summer, on an average of 2.5 hrs a day.marktownley wrote: ↑Sun Jan 15, 2023 11:24 am Interesting thanks Martin, just found them on Amazon over here.
The chip temperature holds steady at around 40 degrees Celsius in a ASI174 camera .These run hotter than ASI290 cameras.
Even after 2.5 hours the camera body is cool to touch.
The good thing is you can buy extra magnetic pads cheaply on AliExpress and swap the coolers between cameras.
Martin
