Hi All,
Has anyone encountered the "flashing line or lightning" appearance of the live image view of Firecapture 2.7 (latest version). It looks like lightning !
Here is one example, not all of them look like this.
Does anyone know the cause ? It does not seem to happen in SharpCap usually. Changing the USB3.0 cable may be the answer.
Thanks guys!
Magnus
Bright streaks in Firecapture !
- Has thanked: 21003 times
- Been thanked: 10629 times
Re: Bright streaks in Firecapture !
A new one on me!
- Has thanked: 65 times
- Been thanked: 4470 times
I am using the latest Firecapture but have not witnessed this effect.
I'd suggest posting to the FireCapture group if the USB cable change doesn't solve it
Whist using SharpCap with no apparent problems, the cable might be the snag, but can be proved by reinstallation of Firecapture...
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Thanks Terry, Brian and David,
I will try the 1) reinstalling Firecapture and looking at my Firecapture settings and 2) use a different USB 3.0 cable.
It could be my second hand laptop, but Sharpcap does not bring this problem usually.
It may have to wait until the Spring - March/April, as the sun is too low and I would have to setup in the garden when the sun is low.
Thanks.
Happy New Year/2023 !!
Magnus
Thanks.
Magnus
