29 Dec 2022, Animation of Christmas tree Prom, post Flare Loop & Surge
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Hi all,
I hope this finds you well.
Yesterday I had a nice observation and was lucky with my animation targeted captures (despite the tuning problems).
I had them 'all in one', a Christmas Tree Prom, a past Flare Loop (which originally attracted my attention), and a Surge next to it.
However, I did not know how to present the animation. I would have spent even more time to try to invert the sun surface or the proms. I may try this later. I present you four different options and please let me know which one you prefer, if you wish.
(almost) Full frame with proper orientation
2022-12-29, 36 min Animation, Sun E limb, Lunt130MT, H-alpha DS, ASI290MM, 12_41_24, Full frame by H- Alpha, on Flickr
Rotated 90 clockwise and cropped
2022-12-29, 36 min Animation, Sun E limb, Lunt130MT, H-alpha DS, ASI290MM, 12_41_24, Rotate 90, cropped by H- Alpha, on Flickr
Rotated 90 clockwise, cropped and sun surface masked
2022-12-29, 36 min Animation, Sun E limb, Lunt130MT, H-alpha DS, ASI290MM, 12_41_24, Rotate 90, cropped, surface masked by H- Alpha, on Flickr
Rotated 90 clockwise, cropped with colour
2022-12-29, 36 min Animation, Sun E limb, Lunt130MT, H-alpha DS, ASI290MM, 12_41_24, Rotate 90, cropped, colour by H- Alpha, on Flickr
Only after uploading this post, I realized this annoying flickering on the solar surface and cannot understand to what it is due... Chmmmm... I had it in the past in animations much longer in less intensity. I made a batch process of frames, so I cannot really explain why it is so important. Possibly very thin clouds? It could be.
Alexandros
Alexandros
Alexandros
Greece
Greece
- rigel123
- Has thanked: 8314 times
- Been thanked: 8540 times
Re: 29 Dec 2022, Animation of Christmas tree Prom, post Flare Loop & Surge
Wonderful catch Alexandros! I'm torn between the 2nd and 3rd one. I like the details that show in the 2nd one since you can see the involvement of the surface but of course there is less flashing in the 3rd since the disk is blacked out which masks the effect of high clouds that definitely causes the flickering of the disk. I did run that 2nd animation through Pixinsight's Batch Linear Fit which can help when you have a variation in the histogram between frames in your animations.
Alexandros adjusted 12 30 2022 by Rigel123, on Flickr
- H-Alpha
Thanks a lot Warren!rigel123 wrote: ↑Fri Dec 30, 2022 6:30 pm Wonderful catch Alexandros! I'm torn between the 2nd and 3rd one. I like the details that show in the 2nd one since you can see the involvement of the surface but of course there is less flashing in the 3rd since the disk is blacked out which masks the effect of high clouds that definitely causes the flickering of the disk. I did run that 2nd animation through Pixinsight's Batch Linear Fit which can help when you have a variation in the histogram between frames in your animations.
Fantastic improvement in Pixinsight! I had downloaded it last summer while learning to process Deep Sky photos and was quite difficult. Then I stopped DS due to planets apparition and did not buy it. I will at a certain moment. When you learn it it it can do fantastic things apparently. I am curious, how long did it take for you to correct the flickering in the animation?
Alexandros
Alexandros
Greece
Greece
- Has thanked: 9411 times
- Been thanked: 5571 times
Excellent
- Been thanked: 16694 times
Alexandros,
I observed this prom and the surge area north of it visually yesterday though it looked a bit different visually at the time I observed. The prom itself was very easy with nice detail and the surge area north of it was easily seen but I never saw any of the plasma streams between them. Either I observed before or too far after the flare that caused them or they were too faint for me to pick up in double-stack.
These are really nice animations. They show so much more going on than a visual view or still image can show. Which way does the plasma flow in the streamers go? Away from the big Christmas tree prom or towards it? They go away in the first four and towards in the last one edited by Warren.
Also look at the movement of the spicules/plasma around the big spot of AR13176 in your first image. I noticed a defined area around that spot on the 27th. Fascinating...
P.S. The flicker is a minor thing in such a good set of animations.
- H-Alpha
Thanks a lot James!DeepSolar64 wrote: ↑Fri Dec 30, 2022 10:52 pm
I had a feeling that you would write that you observed all this visually, and here you are! ;-)
I also had not observed the plasma until I processed the first test capture! It was very faint apparently.
Best wishes for a Happy New Year!
Alexandros
Alexandros
Greece
Greece
Alexandros,
With you being in Italy you probably imaged the area several hours before my visual view of it. While one can observe change real-time visually the sped-up time in animations make it so much more obvious!!
I see and you animate!!
Happy New Year to You and Your Family too!!
- rigel123
H-Alpha wrote: ↑Fri Dec 30, 2022 7:25 pmThanks a lot Warren!rigel123 wrote: ↑Fri Dec 30, 2022 6:30 pm Wonderful catch Alexandros! I'm torn between the 2nd and 3rd one. I like the details that show in the 2nd one since you can see the involvement of the surface but of course there is less flashing in the 3rd since the disk is blacked out which masks the effect of high clouds that definitely causes the flickering of the disk. I did run that 2nd animation through Pixinsight's Batch Linear Fit which can help when you have a variation in the histogram between frames in your animations.
It takes very little time at all. I first opened your animation in Photoshop and then exported the layers as files into a folder. Then in Pixinsight I open up Scripts/Batch Processing/Batch Linear Fit. I select all the images in the folder I moved the files to, then I select the one image I want to match the histograms to. In this case I picked one of the images that looked the best. You then make a folder for the files, change the output so the files are saved as TIF's and hit run. The adjusted files can then be made back into a GIF or other media of your choice. Here is a quick tutorial I put together for doing this: https://youtu.be/IKZmipr0mYs
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
Wow, fantastic animation Alexandros. You got the trifecta!!
No 1 for our vote.
No 1 for our vote.
Clare & Peter
- Has thanked: 9144 times
- Been thanked: 6025 times
Beautiful work, Alexandros. #3 is my favorite, but they are all very good.
- Been thanked: 8790 times
Wow!! that does look like a Christmas tree
Fabulous animations, I like number 1 and 2 best but yes like James said, I am presuming Warren's is reversed?
Happy New Year!
Happy New Year!
- rigel123
Yeah, I forgot to reverse the frames which Photoshop does for some reason! I replaced the file with the correct sorting of the frames
- Been thanked: 4786 times
Great animation Alexandros.
- H-Alpha
Thanks a lot Warren!rigel123 wrote: ↑Sat Dec 31, 2022 3:24 am
Very good tutorial. I downloaded it in my folder of very useful ones. I am tempted to buy PixInsight only for this, although as I wrote already I had the trial version to work some deep sky photos.
Happy New Year!
Alexandros
Alexandros
Greece
Greece
- H-Alpha
Thank you all for your kind comments on the animation and even more those who ...voted for their preferred version. ;-)
Happy New Year to all!
Alexandros
Greece
Greece
