Close up images from 8 January 2023
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
These are our close up images in 540nm and Ha for this morning.
AR3180 AR3181 AR3182 AR3183 and AR3177 NW prom There has been interest in people's set ups so this is our set up for these close up Ha images.
Clare & Peter
- Been thanked: 4786 times
- Averton
Re: Close up images from 8 January 2023
Really! These images are so good and detailed, that no need to try to make them "better" doing inversion.
I hope (and I wish) that the seeing will be friendly to Clare & Peter as it was yesterday.
- rigel123
- Has thanked: 8310 times
- Been thanked: 8537 times
Wonderful shots and the details in the WL images is amazing!
- Averton
Thank you Valery
Clare & Peter
- Averton
- Been thanked: 4340 times
Clare & Peter...
Superb series of images
Nice to see the equipment used too!
- Has thanked: 17666 times
- Been thanked: 8787 times
Wow!! such care in each image, beautiful quality
You have a lot of wires, what are all the wires for (other than camera and Quark)?
- Has thanked: 6181 times
- Been thanked: 7142 times
- Been thanked: 16691 times
Wonderfully done Clare & Peter!!! I love the setup too. What scope is this?
- Averton
Thanks BrianMapleRidge wrote: ↑Sun Jan 08, 2023 12:57 pm Clare & Peter...
Clare & Peter
- Averton
Thanks Alexandra
Cabling as follows.
1/ Power to the Quark
2/ Primary camera cable to the ASI174MM
3/ Power to the peltier cooler on the ASI174MM
4/ Secondary camera cable to the guide camera ASI120MM mini
5/ ST4 cable between the guide camera and the mount
We could be a little neater with some better cable management, but as we have to swap quite a deal from one configuration to another it does get a bit messy.
Clare & Peter
- Averton
- Averton
Thanks James!DeepSolar64 wrote: ↑Sun Jan 08, 2023 6:41 pm Wonderfully done Clare & Peter!!! I love the setup too. What scope is this?
The scope is sold in Australia as a Kson A102G.
It is an achromatic air spaced doublet 102mm refractor. The glass is nothing special, pretty much a Chinese version of BK7.
As we are only asking the scope to focus on a single wavelength, CA is not an issue.
Being a fairly basic scope it was a good price. The build is of good quality. The focuser, although only a rack and pinion, is robust and carries the weight of the accessories quite well.
Clare & Peter
- Has thanked: 20424 times
- Been thanked: 10243 times
Very nice pictures of our star, and nice to see the setup too.
Averton wrote: ↑Mon Jan 09, 2023 11:30 amThanks James!DeepSolar64 wrote: ↑Sun Jan 08, 2023 6:41 pm Wonderfully done Clare & Peter!!! I love the setup too. What scope is this?
I have a Celestron 102 achromat. F9.8. It does very well with a wedge and 540nm filter. It’s probably very similar to yours.
- Averton
Thank you Markmarktownley wrote: ↑Mon Jan 09, 2023 7:53 pm Very nice pictures of our star, and nice to see the setup too.
Clare & Peter
- Averton
Yes, they sound very similar except we didn't add that the Kson is a little faster at F7.DeepSolar64 wrote: ↑Mon Jan 09, 2023 10:09 pmAverton wrote: ↑Mon Jan 09, 2023 11:30 amThanks James!DeepSolar64 wrote: ↑Sun Jan 08, 2023 6:41 pm Wonderfully done Clare & Peter!!! I love the setup too. What scope is this?
Clare & Peter
Averton wrote: ↑Tue Jan 10, 2023 5:16 amYes, they sound very similar except we didn't add that the Kson is a little faster at F7.DeepSolar64 wrote: ↑Mon Jan 09, 2023 10:09 pmAverton wrote: ↑Mon Jan 09, 2023 11:30 am
Thanks James!
I like the white tube of yours better. Black like mine is can be too susceptible to daytime heating! Mine being a longer F-ratio probably has a lower amount of CA but since we usually use narrowband filters that isn't an issue as you have previously stated.
- Has thanked: 8415 times
- Been thanked: 8161 times
A beautiful set of images. Lots of lovely details in these. Nice to see your setup too.
- Has thanked: 9144 times
- Been thanked: 6025 times
A superb set, Clare and Peter ! I don’t know the K102 scope… can you please describe a bit ? All images are great, love the prominence at the end.
- Averton
- Averton
Thanks Franco
It is an achromatic air spaced doublet 102mm F7 refractor. The glass is nothing special, pretty much a Chinese version of BK7.
Clare & Peter
- Been thanked: 4904 times
Clare & Peter:
Beautiful clean and crisp images all of them and a nice setup.
Thanks for sharing them.
Best regards.
Best regards.
- Has thanked: 2924 times
- Been thanked: 424 times
Grand set of images thank you for sharing
Bill
Bill
Lunt pressure tuned 60mm
Orion ST 80mm
Bausch and Lomb 90mm
Starfield 2" herschel wedge
various Barlows and Filters
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
Apollo Mini IMX 429m
Apollo -M Max IMX 432m
Sky Watcher SolarQuest
EQ 5 Black
Orion ST 80mm
Player one :
Neptune M IMX 178m
Apollo M IMX 174m
EQ 5 Black
- Averton
- Peterm
- Has thanked: 1733 times
- Been thanked: 1488 times
Ripper presentation Clare & Peter. All wonderful but that prom is stunning! Great to see your setup as well. Bravo.
BOSS team: www.bosssupernova.com
- Averton
- Averton
