january 14th AR 3186 and 3190 R and G filters
cte
Has thanked: 383 times
Been thanked: 629 times
Post by cte »
Today I had clear skies after some early morning mist. I thought seeing was decent and took the chance of doing some "hi res" photosphere imaging with the 180 mm mak, R and G filters, and ASi 174 camera. I think when seeing supports the long focal length, it is better to image with the barlow with my combination. The sun was full of active regions, I imaged quite a lot, but here I'm posting what I deem the most interesting ones for the moment. I think a good deal of details can be seen in the umbral and penumbral regions of these spots. In AR 3190, I think a light bridge is well evident. When shooting under ROI conditions I could get close to 200 fps with the red filter, which I think helps a lot in contrasting the turbulence. The pictures attached are the result of stacking the best 20% of a ca. 5000 frame recording, followed by wavelet treatment, LR deconvolution and a little photoshop post processing to adjust levels and curves. I was hoping to do Halpha tomorrow, but the sky here will get cloudy again starting from this evening and will stay so for a few days.
AR3190 G filter 2x televue.jpg (789.49 KiB) Viewed 426 times
AR3186 R filter 2x televue.jpg (1.05 MiB) Viewed 426 times
AR3190 R filter native focal.jpg (325.07 KiB) Viewed 426 times
Has thanked: 17925 times
Been thanked: 8892 times
Re: january 14th AR 3186 and 3190 R and G filters
Superb!! that light bridge is very thin and straight, quite an impressive sight :bow :hamster:
cte
Post by cte »
Thank you Alexandra. The SPOD, is very much unexpected :bow2
It's a great honor to be able to contribute
Martin_S
Has thanked: 999 times
Been thanked: 3060 times
Post by Martin_S »
Hi Cte,180 maks are great for WL, congratulations on the SPOD.
Martin
Peterm
Has thanked: 1801 times
Been thanked: 1554 times
Post by Peterm »
These are magnificent and so good to see highlighted with a SPOD!
Peter
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
Has thanked: 17813 times
Been thanked: 16951 times
Post by DeepSolar64 »
Beautiful detail on both of these regions. The light bridge in the big spot of AR13190 is quite striking. Quite bright and very thin. Does it connect to the faculae outside of the spot on one side or is it just me?
AR13186 shows really nice detail with the fibrils ( Penumbral striations ) and the detail in the eastern spots in the group showing very well.
Congratulations on the SPOD!!
Averton
Has thanked: 3303 times
Been thanked: 2312 times
Post by Averton »
Wow, great images with lovely detail. Congratulations on the SPOD!!
Clare & Peter
Has thanked: 9294 times
Been thanked: 6129 times
Post by ffellah »
Pretty spectacular image and SPOD, Ctr, very well done 👍
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Beautiful detailed images, congrats on SPOD 👍
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Good WL session!
Thanks for sharing.
arnedanielsen
Has thanked: 6276 times
Been thanked: 7294 times
Post by arnedanielsen »
Beautiful WL!
Congrats on SPoD!
Arne
Arne
cte
Post by cte »
Hi James,
Here I am attaching an inverted image to try to provide some more evidence to your insight about the structure of the light bridge. I think you are right, the light bridge is departing from the faculae outside the spot, it seems there is actually a ramification of the bridge in three of four lanes.
Thank you guys for all your support, this is a really great forum, I will keep working to improve my imaging skills.
AR3190 G filter 2x televue inverted.jpg (775.87 KiB) Viewed 327 times
Awesome. I think this is the first time I have seen a light bridge affect the immediate region outside of a spot. In your inverted image it shows evidence of even an extension into the faculae on the northern edge!
Has thanked: 20743 times
Been thanked: 10439 times
Great shots!
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Very nice images, especially the second one with lovely granulation and penubral details.
