I had to use my Esprit 100ED today as seeing was bad. It's been rain, clouds and freezing temperatures here in LA, but we have a clearing for a few days so I had to grab what i could get.
Jan 17 2023 - Go small or go home!
- Has thanked: 1075 times
- Been thanked: 1986 times
- Peterm
- Has thanked: 1802 times
- Been thanked: 1554 times
Re: Jan 17 2023 - Go small or go home!
Wow there is some detail in those!
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
- Has thanked: 17845 times
- Been thanked: 16977 times
Simon.
I don't usually consider 100mm " small " but medium sized. But I guess that depends on what scope you usually use that is bigger.
Surprisingly I like the mono better than the color. The details stand out better. And the middle positive image is my favorite. All are great though!!
- Has thanked: 20779 times
- Been thanked: 10462 times
Nice disk there Simon!
For me, anything around the 100mm and below is considered small - I guess you get spoiled when you have a 150mm and a 204mm.
DeepSolar64 wrote: ↑Wed Jan 18, 2023 3:42 am Simon.
I certainly would consider it small for a reflector or a deep-sky scope. I have 304mm, 251mm and 152mm reflectors that I use mainly for deep sky but a 102mm refractor is the biggest scope I have set up for solar use.Simon2940 wrote: ↑Thu Jan 19, 2023 2:25 am For me, anything around the 100mm and below is considered small - I guess you get spoiled when you have a 150mm and a 204mm.
You might be a bit spoiled ;-)
- Has thanked: 8543 times
- Been thanked: 8280 times
Good images, Simon.
- Has thanked: 6296 times
- Been thanked: 7308 times
