20th Jan 2023 Sun images
- Been thanked: 1648 times
20th Jan. A clear day but a rough atmosphere made it difficult to image the sun well. The first image is at 540 nm to show the sunspots. The dominant regions are AR 3190 and AR 3192.
The other 3 images are at Halpha wavelength (656 nm) to show the chromospheric features.
All images are single exposures with a Canon 550d.
Thanks for viewing.
Thanks for viewing.
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Re: 20th Jan 2023 Sun images
Nice work John - so much to see in WL & Ha. Hoping for the large Filament to lift off over the weekend!
- Has thanked: 8588 times
- Been thanked: 8324 times
Nicely imaged, John.
- Has thanked: 2501 times
- Been thanked: 4926 times
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Fantastic images John.
Alun
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 9387 times
- Been thanked: 6199 times
- rigel123
- Has thanked: 8659 times
- Been thanked: 8895 times
Excellent shots John! Knowing they are single shots, do you take a burst of shots and cull out the best in the series?
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
- Has thanked: 17960 times
- Been thanked: 17105 times
Nice imaging work, John!
Thank you all for your comments.
Reply to Warren (rigel123)... no I just take frames one at a time not in bursts. On average I take 3 shots spaced apart at 540 nm for the sunspots and use the best one, and up to 6 for the Ha shots of different sectors spaced apart.
Cheers, John W.
Cheers, John W.
- Has thanked: 9821 times
- Been thanked: 5826 times
Great Job ...
- Has thanked: 65 times
- Been thanked: 4459 times
An excellent series of images John
- Has thanked: 20948 times
- Been thanked: 10588 times
These are excellent John, thanks for sharing!
