Valery,
I use a SolarSpectrum 0.7A that I have double stacked, to see more depth and surface details.
I asked owner Oliver Smie from Beloptik Germany (Dresden) to think about a double stack solution for my setup and he suggested the SolarScope UK etalon.
Indeed there is no information about that etalon on his website, just email Oliver and he will answer fore sure.
After a short waiting time, I have double stack it with the received SolarScope UK (the original from Isle of Man) 30mm from Beloptik.
It works very well in the configuration and has no ghost image.
The SolarScope UK 30mm etalon is already mounted in a 2" tube (cell ... adapter...) with in-build tilt mechanic and a small tuning wheel (pic 3), the 2" cell has T2 thread on both ends M/F.
I use the Baader M68 Tele-Compendium to avoid sag in the imaging train and inside the Tele-Compendium there is a 5x Telecentric again from Beloptik Germany. (5x Telecentric a time ago suggested by you Valery, thanks for that).
On "my website" you can see more about the SolarSpectrum and SolarScope UK etalon setup under "Equipment".
Here some pics from the SolarScope 30mm etalon and configuration with the SolarSpectrum and Baader Zenith Prisma!
In the configuration, last pic, the SolarScope UK etalon "Double stack" Ha filter with small tuning wheel, between the Baader prisma and the Baader M68 Tele-Compendium.
Only a small part with the little tuning wheel is visible.
So the SolarScope T2 male thread (pic 1-3) mounted on the Baader Prisma and the SolarScope 2" cell (pic 2) inside the Baader M68 Tele-Compendium ... (pic 4).
SolarScope etalon
Re: SolarScope etalon
Thanks, Maurits!
What is the price for this 30mm etalon?
- Has thanked: 20783 times
- Been thanked: 10464 times
That is a very good price!
Really? LS35 and LS40 are much cheaper, I believe. I do use my LS35 to double stack my Quarks and it works just fine.
Valery.
- Has thanked: 1188 times
- Been thanked: 1382 times
I think with the release and price of the Lunt 40, it is likely the best etalon for custom jobs, both primary or double stacking. No crazy work to harvest it. Simple known threads to adapt it. Easy to just put it behind a true telecentric amp and you're in business. And if Lunt releases it as a double stack (soon?) it will be even less expensive to get two of them. They are short, so you could get two Lunt 40's and have RAF Camera make the holding chambers, a Baader TZ4 telecentric and the two Lunt 40's in their chambers stacked together will be less than 200mm, and work very well with the telecentric. A blocking filter can be put before the 2nd etalon, or after both, depending on the camera used. The IMX432 doesn't need a reducer, so it makes more sense to use that with such a setup and avoid a reducer. This could be built for around $2k +the RAF camera chamber's cost.
Granted, that's in the States (Lunt). I imagine a UK origin item might be a better price for folk in EU/UK/Asia?
Maybe, I think Marty hits it on the head. Maybe exchange rate is a factor. I agree the Lunts are cheaper in their raw form.
