Good old AstroRod spotted a Scopetech 80mm F15 on ebay locally, and I was under some emotional pressure to buy it.
It is lovely and contrasty on the Moon. Pinpoint stars. Bit small aperture really for planets.
Need some clear skys to try it out.
Cheers. Andrew.
20230131123012Ch HR by Andrew Huskinson, on Flickr
https://www.kso.ac.at/index_en.php
https://solarmonitor.org/forecast.php?d ... 31®ion=
https://www.raben.com/maps/
High FNo
- Has thanked: 3317 times
- Been thanked: 1907 times
- Has thanked: 20813 times
- Been thanked: 10487 times
Re: High FNo
That sounds like a nice scope Andrew. What is the focuser like?
Thanks for todays report. I might see some sun tomorrow if i'm lucky.
Re: High FNo
The former owner was on Stargazers lounge.
He chopped the tube to get a diagonal in. Carbon Fibre sides.
Its well made and the focusser is good. Rod could see some epoxy holding it together from the top.
Rod was waving a 2" focusser from one of his upgraded scopes about so that looks like it will go on.
25x with a 56/55mm 2".
Cheers. Andrew.
Cheers. Andrew.
- Has thanked: 17853 times
- Been thanked: 16993 times
Re: High FNo
An 80mm long focal ratio achromat. Nice!! It might surprise you what it will do on planets in good seeing.
- Has thanked: 9319 times
- Been thanked: 6157 times
