Feb 2nd. Those of us who have been following the sunspot activity on the Sun during January 2023 would have expected to see an increase in the official sunspot number for the month. Well the number is 143.6, which is much higher than expected and higher than the December 2022 figure of 113.4. Remember the observed sunspot number is calculated by a special formula (you can look it up). If the current trend continues, Solar Maximum will either happen sooner or be stronger than originally expected–possibly both. It will be interesting to see what happens during February.
The first graph shows progress of the current solar cycle (25): observed monthly sunspot number (thin yellow), observed smoothed monthly sunspot number (thick turquoise) and predicted smoothed monthly sunspot number (magenta crosses).
This graph is provided by the Australian Bureau of Meteorology Space Weather Service and is based on the observed monthly mean sunspot numbers from WDC-SILSO, Royal Observatory of Belgium, Brussels. The graph shows that January’s figures are much higher than expected.
The second graph sourced from the Space Weather Predication Centre /NOAA, shows similar figures for the sunspot numbers but has a different prediction line based on a different forecast model to that above.
We will watch with interest as actual numbers come in for each month of this year.
2nd Feb Sunspot numbers going up !
- Been thanked: 1577 times
- Been thanked: 16694 times
Re: 2nd Feb Sunspot numbers going up !
WoW, that's an impressive spike in sunspot activity for January. February is beginning much calmer though. I am certainly curious to how SS25 is going to pan out.
Thanks for the info.
- Been thanked: 8791 times
Great information John the spots have calmed down a bit so the peak will even out a bit over the next few weeks. Let's hope it keeps giving these January peaks, I'm enjoying it
- Been thanked: 4787 times
- Been thanked: 10247 times
Thanks for the update John!
- Has thanked: 8418 times
- Been thanked: 8163 times
Good information. Thanks, John.
I suspect February will be a dip in the graph.DeepSolar64 wrote: ↑Thu Feb 02, 2023 5:37 am WoW, that's an impressive spike in sunspot activity for January. February is beginning much calmer though.
Thanks Mark - I suspect February's figures will be lower as well.
John W
John W
- Has thanked: 9414 times
- Been thanked: 5578 times
If you have not seen it, here another article about the Solar Cycle 25
https://www.spaceweatherlive.com/en/new ... cbytE.html
https://www.facebook.com/spaceweathertrackers
