Is it feasible to use a 4x Telecentric for 7200mm focal length and get an image on a chip.
Whats the best option for a focal reducer if it is possible?
Cheers. Andrew.
180mm F10 and Quark Combo
- Has thanked: 3317 times
- Been thanked: 1907 times
- Has thanked: 4379 times
- Been thanked: 3976 times
Re: 180mm F10 and Quark Combo
It depends on your viewing conditions. If they are excellent, the focal length of 7m is not a big problem for a camera with IMX432 or IMX533 BIN2-3.
Good reducers are produced by Baader, 0.7x and 0.4x. They are intended for solar telescopes.
- Has thanked: 20813 times
- Been thanked: 10487 times
You can get an image on a chip, what camera are you using? The pixel size will dictate the factor of the reducer.AndiesHandyHandies wrote: ↑Sat Feb 04, 2023 12:06 pm Hi
Cheers. Andrew.
Personally, if you are going f10 then get a TZ3 rather than TZ4.
My alarm bells ring more about local seeing at this aperture.,
Hi Mark,
Well Baader seem to like F30, for their 6" F15 solar Coude'?
I have a 1.25" 3x VK Telecentric I can try.
I have no large camera at the moment. I can borrow a 174.
Occasional use of course. So on hand bits. I have a standard 0.5x.
I have a reasonable site for seeing on a cliff edge with field beyond. Till we reach a church.
Cheers. Andrew.
Cheers. Andrew.
For visual.
Using a Combo Quark at 6x on a F6.7 90mm at F40 and 3600mm FL works OK.
And my new 80mm F15 likes 2x at F30 and *** 2400mm *** FL.
I am sure the Mak 180mm F10 will do OK with a 2x Extender for 3600mm FL for visual. I think longer in the past was too much.
Cheers. Andrew.
For visual.
Cheers. Andrew.
Last edited by AndiesHandyHandies on Thu Mar 02, 2023 2:44 pm, edited 1 time in total.
- Has thanked: 3058 times
- Been thanked: 2161 times
I think with the Quark combo you want at least F/30 at the etalon. Reducing would be afterwards but the etalon is so small that its not suited for visual use in this case. So you need good seeing for visual use at F/30.AndiesHandyHandies wrote: ↑Sun Feb 19, 2023 11:29 am Hi
For visual.
And my new 80mm F15 likes 2x at F30 and 3600mm FL.
Cheers. Andrew.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
