Couple of spectroheliograms taken earlier today in the CaK line and the CaK II 8542.1 line using my 72ED with Herschel wedge/Sol'Ex and QHY5III 178M.
Because of the limited travel in rotation with the 2400l/mm grating after having captured the CaK line scans I swapped it out for a 1200l/mm so as to allow access to the CaK II line,this grating has seen better days and seriously needs replacing due to the reflective coating breaking down,also added a Infrared Pass (807) filter to the front of the camera to act as an order filter. Reconstruction in SER MAIN Ver 3.7 and apart from resizing and rotation to
correct orientation no other processing has been carried out on these two single scans. x16 slew speed used on CEM60 to force the scan of the solar disk.
Alun
Spectroheliograms from 15th Feb 2023
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 18146 times
- Been thanked: 8948 times
- Has thanked: 48 times
- Been thanked: 1543 times
Re: Spectroheliograms from 15th Feb 2023
That's really good with 854.2nm. I was never able to do so well (I think my telescope triplet optics don't work well in the IR).
If you want to reduce the horizontal stripes in the Calcium images, I would recommend reducing the "transversalium correction strength" to 1.0 or lower. It is a kind of low pass filter and if there are very high contrast features, it causes the effect you see (particularly in the IR wavelength).
If you plan on getting a replacement for the 1200 l/mm grating, you might consider a 1800 l/mm.
- Alun_H
Thank you Alexandra,Douglas.
I will play around with the transversalium correction tool as I must admit I have a tendency to leave it at around 1.8-2.0. Before I get another grating,and thanks for the tip on the 1800,I am going to try and extend the travel of the gratings rotation in an attempt to reach the IR with the 2400.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
It is in fact impossible. The angle goes beyond 90 degrees. See the SimSpec SHG spreadsheet.
- Alun_H
I found the angle will be too tight when I checked the grating holder,so the 1800l/mm grating will be added to the shopping list along with the filter
for my CaK module as well as the other astro bits I need
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 21007 times
- Been thanked: 10629 times
Amazing stuff!
- Alun_H
Thank you Mark.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
