A couple of spectroheliograms taken on the 14th Feb with the 72ED,Herschel wedge and Sol'Ex/QHY5III 178M in the lines of Hbeta and Mg 1 (b2),this being the middle line of the Magnesium triplet. Single scans and only processing carried out is rotation to correct orientation,resizing and slight adjustment of brightness levels. Mg 1 scan was affected by drifting clouds.
Alun
Hbeta & Mg 1 (b2) spectroheliograms 14th Feb 2023
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 9417 times
- Been thanked: 5582 times
Re: Hbeta & Mg 1 (b2) spectroheliograms 14th Feb 2023
Great results. I am still struggling in getting a reliable result in H-alpha.
Which of the 3 Mg lines from the triplet did you choose ? At the moment I do not understand where the Mg 1 (b2) is. Is it the lowest nm or highest nm value ? Thanks
Rainer
Rainer
- Alun_H
Thank you Rainer, the Magnesium Triplet is in the green region of the spectrum between 516.7nm (Mg 1 b4) and 518.3nm (Mg 1 b1)
The line I chose,the Mg 1 b2 is marked in this picture and lies at 517.2nm
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
Thank you very much. I once tried that but I should have chosen only one line and I chose 3 liunes and of course it was a total mess
At the moment it is cloudy.
Rainer
Rainer
- Alun_H
Yes,been there and done that myself,ended up with series of black lines covering the image due to ROI being too wide
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 42 times
- Been thanked: 1487 times
I've always liked H-beta. The narrow line width means that a lot features are visible, and at the fairly short wavelength, the spatial resolution is very good. It has a lot in common with H-alpha but still looks dramatically different. There are very few commercial filters available in H-beta so the images are quite unique to this technique. It's always nice to compare H-alpha and H-beta taken on the same day.
I think it's nice to compare the non-hydrogen lines to continuum images. You can do this by using a pixel offset to the spectral line in question. You just need to make sure the data off the line is not overexposed.
- Has thanked: 57 times
- Been thanked: 1189 times
h -beta one of my favorites
reason i made my own SHG
Mg b2 is cool also - like a watered down caK
- Been thanked: 10248 times
I missed these! Really well done Alun!
- Alun_H
Thank you Mark.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
