ZWO ASI 533MM for solar (Ha) imaging???
Has thanked: 174 times
Been thanked: 618 times
Post by Merlin66 »
Is anyone using the ASI 533MM for solar imaging?
What's the feedback?
Does the ASI 533 suffer from the same Ha artefacts as the ol' ASI 183???
thesmiths
Has thanked: 47 times
Been thanked: 1522 times
Re: ZWO ASI 533MM for solar (Ha) imaging???
Post by thesmiths »
In my recent post on the discontinuation of the ASI1600MM viewtopic.php?t=39659, I mentioned the ASI533MM. My basis for thinking this was a good successor camera was the series of images from Peter Ward in Sydney, who has been using a QHY533M since around November 2022:
search.php?author_id=966&sr=posts
The QHY and ZWO seem to use the same Sony IMX533 chip. The QHY is cooled, while the ZWO comes in cooled and uncooled versions.
Peter is using double-stacked front-mounted etalons, which must give a pretty narrow bandwidth, so is likely a good test.
I doubt that the cooling is really necessary for strictly solar use. I've noticed that more modern camera sensors actually stay cooler (this might be the sensor but could also be more efficient support electronics).
Also, while the ASI1600MM cooled version could function without an external power supply, the newer cooled ZWO cameras will not be recognised by the computer without the external power source attached.
I've heard some people complain about the 1-inch square sensor with regards to deep sky imaging. But for solar and lunar, a square sensor actually makes more sense.
Post by Merlin66 »
Doug,
Thanks for that, overlooked Peter....
I'm assuming the electronics are very similar between the ZWO and the QHY cameras.
Ken
thesmiths
Post by thesmiths »
While quantum efficiency is not so critical for solar imaging, the old 1600MM is about 40% efficient, while the newer sensors like the 533MM are about 50% efficient at 650nm (based on charts I've seen by C. Buil).
Post by Merlin66 »
The problem was the artefacts seen with the ASI 183mm camera, and whether or not these would be an issue with the ASI 533.
I think Peter's image may suggest they are not an issue!
Ken
pupak
Has thanked: 4376 times
Been thanked: 3973 times
Post by pupak »
I use Player One Saturn with IMX533M. Ideal for solar photography, it is light and has an adjustable chip tilt.
It works reliably in all programs.
Post by Merlin66 »
Are you seeing any artefacts on narrow band H alpha imagining????
thesmiths
Post by thesmiths »
The Player One Saturn-M SQR version looks really good for solar in a number of ways. For example, the built-in tilting mechanism and the (optional) external fan cooler. See the nice result below, taken from the Player One website. My conclusion is the Sony IMX533 chip is good for solar.
Jean Pierre Brahic, 230MM refractor + Solar SPectrum 0.3A + Saturn-M SQR camera
Solar-activity-Jean-Pierre-Brahic-230MM-refractor-Solar-SPectrum-0.3A-Saturn-M-SQR-camera-scaled.jpg (1.01 MiB) Viewed 3903 times
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Player One camera with the IMX533 is faster in term of fps compared to the ZWO equivalent. I don't know the reason why.
This is a big plus for the Player One.
pupak
Post by pupak »
christian viladrich wrote: Thu Feb 23, 2023 6:49 pm Player One camera with the IMX533 is faster in term of fps compared to the ZWO equivalent. I don't know the reason why.
I owned the QHY533M and the Player One Saturn M at the same time for a short time, so I did a comparison and both cameras had the same FPS at all resolutions. Only QHY was more sensitive to the quality and length of the USB cable. With a longer cable, the FPS went down quickly at 9 MP.
thesmiths
Post by thesmiths »
The Player One planetary cameras now all have on-board DDR3 memory. That might be the reason. ZWO typically only puts this on their DSO cameras. Player One claims:
256M DDR3 Cache
Player One Astronomy cameras are the first one who adopts the DDR3 cache in all planetary cameras in the world! It helps stabilize and secure data transmission, it effectively avoids frame dropping and greatly reduces readout noise.
With the DDR3 cache, the camera does not have high demands on computing needs any longer, it will still has excellent performance even if it is connected to a USB 2.0 port.
christian viladrich
Has thanked: 1 time
pupak wrote: Thu Feb 23, 2023 7:58 pm I owned the QHY533M and the Player One Saturn M at the same time for a short time, so I did a comparison and both cameras had the same FPS at all resolutions. Only QHY was more sensitive to the quality and length of the USB cable. With a longer cable, the FPS went down quickly at 9 MP.
This is good to know. So the "issue" is only with the ZWO camera.
BTW, I've found a very good 7.5 m USB3 active extension with no fps drop.
https://www.amazon.fr/MutecPower-30m-C% ... PSUTA?th=1
thesmiths
Post by thesmiths »
With regards to Player One: I noticed that their new APS-C size cooled camera, the Poseidon-M Pro, has a USB-C plug and says the cable is USB 3.2 standard (rather than USB 3.0). This new camera competes with the ZWO 2600MM (and one from QHY). Player One also puts double the DDR3 memory on-camera than their competitors (512MB vs 256MB). It looks like their data download times might be quicker.
I've thought for awhile that USB-C is they way to go for future cameras so nice to see one manufacturer is moving in that direction. I think USB-C can also deliver more current as well as higher speeds.
Dennis
Has thanked: 3053 times
Been thanked: 2152 times
Post by Dennis »
thesmiths wrote: Fri Feb 24, 2023 4:21 pm With regards to Player One: I noticed that their new APS-C size cooled camera, the Poseidon-M Pro, has a USB-C plug and says the cable is USB 3.2 standard (rather than USB 3.0). This new camera competes with the ZWO 2600MM (and one from QHY). Player One also puts double the DDR3 memory on-camera than their competitors (512MB vs 256MB). It looks like their data download times might be quicker.
Thats interesting, could you send me the link to the statement with usb 3.2? Couldnt find it.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
thesmiths
Post by thesmiths »
Dennis wrote: Fri Feb 24, 2023 4:32 pm could you send me the link to the statement with USB 3.2? Couldn't find it.
The Player One site is a little weak on specs (and they don't seem to have online manuals for specific cameras either). I'm guessing about the USB 3.2 from the following graphic (see item 7):
Poseidon-M Pro
Poseidon-M Pro
I also looked at this graphic from Kingston:
USB3 standards
USB3 standards
I'm assuming that the reason they include a USB-C to USB-3.2 cable is that the interface supports this. I could be wrong about that. There are some other references to USB-3.0 on the website but who knows what marketing people write. Even if the output is not USB-3.2 currently, at least they are on the path towards it by including the right connectors and cables. Maybe someone can write to their technical support and get confirmation.
Dennis
Post by Dennis »
thesmiths wrote: Fri Feb 24, 2023 6:34 pm
Thanks. Yes the cable seems to support it, would be really nice if things would start to go in the usb3.2 direction.
The camera itself is stated with only usb3.0 capabilities on the player one website.
Triband C9.25
Barlows:
-2x TMB 1.8x
Post by Merlin66 »
OK,
The QHY533M has a 1Gb DDR3 but only available as a cooled camera (astro imaging?!) at us$1159
The ASI 533M has 256Mb DDR3 at us$799
The Player One 533M has 256Mb DDR3 at us$799 (extra us$50 ) for the air cooler.
Pays your money, make a choice...........
(I may just stick with the ASI 1600MM - works for me)
OlegLviv
Has thanked: 911 times
Been thanked: 938 times
Post by OlegLviv »
I have 432mm but only 1.7MP and all bad news...
432mm global+
432mm EQ better+
432mm 9mk+
432mm 8bit 126fps 12bit 106fps+
I think 533mm only for many Megapixels and exactly big resolution and all...
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
thesmiths
Post by thesmiths »
Merlin66 wrote: Sun Feb 26, 2023 11:37 pm The QHY533M has a 1Gb DDR3 but only available as a cooled camera at us$1159
The Player One 533M has 256Mb DDR3 at us$799 (extra us$50) for the air cooler.
I've seen a few people get mislead by specs for megabits (Mb) and megabytes (MB) (one byte = 8 bits). So worth being precise about the usage.
The QHY533M is cooled only and has 1 GByte = 1000 MB DDR3. The weight is 845g (very heavy!).
The ASI 533MM Pro is cooled and has 256 MB DDR3. The weight is 470g (heavy).
The ASI 533MM is uncooled and has 256 MB (which they also refer to as 2 Gbit). The weight is 129g (much lighter!).
The Player One Saturn-M has 256 MB DDR3. The uncooled version is 160g (still quite light). I could not find a spec for the weight of the optional air cooler but I'm guessing it is about the same weight as the camera.
Dennis
Post by Dennis »
Looks like the rolling shutter is not a problem for solar imaging with this cam?
Triband C9.25
Barlows:
-2x TMB 1.8x
pupak
Post by pupak »
Today I used the Saturn M to test the Vixen 90/F15. Shot in BIN1 on F30.
LS40+PST+TZ3x+IMX533M
thesmiths
Post by thesmiths »
Dennis wrote: Fri Feb 24, 2023 6:52 pm would be really nice if things would start to go in the usb3.2 direction.
I just noticed that the newest little camera from QHY, the QHY5III200M, comes with a "USB 3.2 Gen1 Type C Interface". They say,
The new QHY5III (Ver.2) series cameras all use the USB3.2 Gen1 Type-C interface. Compared to the USB3.0 Type-B interface used in the previous generation, the Type-C interface has a longer life and is more flexible.
But it seems again that it's more for the design of the cable connection than to increase the data speed. From the picture on the website, it seems to be running at USB3.0 speed:
Petrus
Has thanked: 1578 times
Been thanked: 747 times
Post by Petrus »
I am the happy owner of the Saturn-M camera, no artifacts or other problems with solar imaging :)
Square chip is great and for my smaller scopes such as Lunt60 and TS 80ED, I can get full disk even with a 2x Barlow lens. Looking forward to see what it can offer this season with the Sun.
~ Petrus ~
Flickr
Dennis
Post by Dennis »
SassySun wrote: Wed Mar 15, 2023 7:33 pm I am the happy owner of the Saturn-M camera, no artifacts or other problems with solar imaging :)
But one downside is the low QE @ 650nm (~57%), thats why im still not 100% convinced.. the imx432 has ~77% there.
Guess i stick to my imx432.
Triband C9.25
Barlows:
-2x TMB 1.8x
Petrus
Post by Petrus »
This is a very good point Dennis! I have this camera also, will be nice to see how they all work with different setups with different results this summer.
~ Petrus ~
Flickr
OlegLviv
Post by OlegLviv »
Guess i stick to my imx432 me too and 533 not global........
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
