Only had a small window of opportunity to get a scan or two earlier this afternoon before the Sun disappeared behind the neighboring houses but I managed to record a scan in the Hydrogen beta and the Hydrogen alpha wavelengths with the 72ED/Herschel wedge and Sol'Ex+ QHY5III 178M.
16x slew speed used on the CEM60 to force the scan,again these are single scans and the only processing after having reconstructed in Ver 3.7 is a resize of the images for posting and rotation/flip to correct orientation.
Alun
Hbeta & Halpha spectroheliograms 2023-02-22
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 20813 times
- Been thanked: 10483 times
Re: Hbeta & Halpha spectroheliograms 23-02-21
Excellent results Alun!
- Alun_H
Re: Hbeta & Halpha spectroheliograms 2023-02-22
Thank you Mark.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 47 times
- Been thanked: 1525 times
- Alun_H
Hi Douglas,I was rushing to capture the data so yes the gain might have been pushed a bit higher.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 17849 times
- Been thanked: 16992 times
Ha & Hb look similar yet different.
What is a scan? I know nothing about one of these except it can image in any spectral line. Because of this they have great potential.
- Alun_H
A scan is where the slit of the spectroheliograph is placed to one side of the solar disk then using a 16x (or less) sidereal speed on the mount and a fast frame planetary camera a recording is made whilst forcing the slit across the disk.DeepSolar64 wrote: ↑Sun Mar 05, 2023 12:48 am
For a more detailed explanation there are a few videos on Christian Buil's Sol'Ex web site http://www.astrosurf.com/solex/sol-ex-o ... on-en.html
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
Thanks for the explanation. The SolEx obviously won’t work with an altazimuth mount?Alun_H wrote: ↑Mon Mar 06, 2023 9:12 amA scan is where the slit of the spectroheliograph is placed to one side of the solar disk then using a 16x (or less) sidereal speed on the mount and a fast frame planetary camera a recording is made whilst forcing the slit across the disk.DeepSolar64 wrote: ↑Sun Mar 05, 2023 12:48 am
Alun
- Alun_H
Douglas answered this very question over on the french Solex-project group and following his advice I 'd say there is nothing to stop the use of an
alt-azimuth mount.
https://groups.io/g/Solex-project/topic ... 4128861246
Alun
alt-azimuth mount.
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
alt-azimuth mount.
Alun
[/quote]
That is surprising. I use three manual mounts and one tracking mount, a Sky-Watcher AZGTI. All alt-az. I’ll read up. Thanks for the links.
