Halpha spectroheliogram 25th Feb 2023
Alun_H
Has thanked: 648 times
Been thanked: 622 times
Post by Alun_H »
Chasing the gaps in the clouds I eventually recorded a few scans in the Hydrogen alpha wavelength earlier this afternoon (15:34 UT) with the 72ED and Sol'Ex but this time round I used the Hoya Pro ND16 filter at the front of the scope in place of the Herschel wedge. The image is a stack of three out of four scans,stacked in Autostakkert and processed in Astrosurface and Photoshop CS2. 16x sidereal on the CEM60 was used to force the Sun across the slit.
Alun
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Then there is all the night kit which is far too long a list to write up here! :lol:
rsfoto
Has thanked: 9677 times
Been thanked: 5750 times
Re: Halpha spectroheliogram 25th Feb 2023
Post by rsfoto »
Hi Alun,
Great positive H-alpha SHG.
¿ ND 16 ? that is a value of 4 stops. What is your exposure time then ?
May I know what filters apart from the ND filter do you have in the light path ?
thesmiths
Has thanked: 47 times
Been thanked: 1521 times
Post by thesmiths »
What's your impression of the ND filter vs Herschel wedge? ND8 might be more appropriate for 72mm.
rsfoto
Post by rsfoto »
What is the length of the travel of the focuser tube of the Evostar 72ED ?
Thanks
Alun_H
Post by Alun_H »
Thank you Rainer,the exposure time is set to around 6.77 milliseconds and I use the gain to alter the brightness (being careful not to push it so increasing noise) with the camera in 1x1 binning.
I don't have any other filters in the light path although at times I will put an Hydrogen Alpha 7nm filter on the nose piece of the Sol'Ex if I want to
cut out extraneous light leakage.
Douglas,I still prefer the Herschel wedge over the ND filter as I still believe the wedge produces a much sharper image. According to Christian Buil on his Sol'Ex web page their is the possibility of fringing with the ND8. http://www.astrosurf.com/solex/sol-ex-observation.html
I only used the filter due to my using the Herschel wedge on my other scope at the time.
Alun
Lunt CaK B12 module
Sol'Ex SHG
Alun_H
Post by Alun_H »
rsfoto wrote: Sat Feb 25, 2023 7:41 pm Hi,
38mm
Alun
Lunt CaK B12 module
Sol'Ex SHG
rsfoto
Post by rsfoto »
Alun_H wrote: Sat Feb 25, 2023 8:00 pm
38mm
Alun
Thanks
Has thanked: 20732 times
Been thanked: 10427 times
Looks good to me Alun!
Alun_H
Post by Alun_H »
Thank you Mark!
Alun
Lunt CaK B12 module
Sol'Ex SHG
Has thanked: 17888 times
Been thanked: 8887 times
Very very nice Alun :bow :hamster:
Has thanked: 17807 times
Been thanked: 16940 times
Post by DeepSolar64 »
Alun,
These look really good. Like you used a normal etalon.
Alun_H
Post by Alun_H »
Thank you Alexandra and James for the kind comments.
Alun
Lunt CaK B12 module
Sol'Ex SHG
Welcome. 🙇🏽
