Just a couple of FDs today (23rd Feb 2023
- Has thanked: 8558 times
- Been thanked: 8290 times
Despite a beautiful morning of horizon to horizon blue sky, the seeing was a tragedy, rendering any close up views completely useless. Anyhow, I really wanted to trial my CaK setup, which comprised a Baader K-line filter, an Omega filter at 393 +/-2nm (apparently, although I don't have the specification) and my Lunt CaK yellow filter. I stripped away the Lunt standard CaK ITFs completely as these are showing signs of ageing. I don't yet have a suitable L1 UV filter, but may purchase one to fit on the front of the 2" tube used to mount the constructed stack. I used my 72mm Altair Lightwave stopped to 43 mm to give an f10 light cone, as recommended by Mark T.
I'm pleased with the results, but I'm also keen to try it out over a range of conditions and on my larger scope (125mm stopped to 80 mm).
Here's the FD imaged as a mosaic:
20230223_CaK_FD_K-Line_Omega_Lunt BF1800 by Stuart Green, on Flickr
I reverted back to the original Lunt B1800 configuration as a baseline comparison:
20230213_CaK_FD_Lunt B1800 by Stuart Green, on Flickr
Here's the first one again, in colour:
20230223_CaK_FD_colour by Stuart Green, on Flickr
A good start, I would say, so further trials planned when the good weather returns.
I finished off with a Ha FD on my Lunt 60. This is a nine pane mosaic, presented in mono and colour. There's a bit of brightness variation across the disk from poor tuning of the triple stack
20230223_Ha_FD_mono by Stuart Green, on Flickr
20230223_Ha_FD_colour by Stuart Green, on Flickr
Thanks for looking.
Thanks for looking.
- Has thanked: 716 times
- Been thanked: 659 times
Re: Just a couple of FDs today (23rd Feb 2023
Gorgeous images. I think the first Ca image with your trial CaK setup is better than the Lunt B1800 - the contrast seems better and the brightness more uniform?
Seeing your images and also Franco's images with his Daystar CaH, I have to say Ca imaging is becoming very very tempting!
- Has thanked: 17849 times
- Been thanked: 16992 times
Stu,
Very nice CaK and Ha discs. I especially love your CaK work.
- Has thanked: 4379 times
- Been thanked: 3976 times
Very nice set of photos.
- Has thanked: 20813 times
- Been thanked: 10483 times
Great disks Stu!
The CaK mod setup is a clear winner over the Lunt CaK.
Next steps, crank the brightness right up with the mod setup, find the ghosts (reflections) and then tilt the appropriate elements to throw them off the disk. If this doesn't work split the 2 elements of the baader k-lin to give considerably more distance between the 2.
- rigel123
- Has thanked: 8573 times
- Been thanked: 8809 times
Excellent disks Stu, the new set up for CaK is extremely good!
Agreed!!
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
H Stu, the first Cak image is really crisp , I think it's a winner!!!
Martin
Martin
Thanks, Mark. Certainly this will require further tweaking. The filters are held in place with PTFE plumbing tape currentlymarktownley wrote: ↑Thu Feb 23, 2023 9:28 pm Great disks Stu!
Heck, that's one of the best ways to do it
- Has thanked: 9318 times
- Been thanked: 6155 times
- Has thanked: 6305 times
- Been thanked: 7322 times
Great results despite the seeing, Stu!
Your new CaK mod looks very promising!
Arne
Arne
Many thanks, Franco, Maurits and Arne.
- Been thanked: 4426 times
Outstanding images Stuart
The modded CaK filter set is certainly an improvement over the original Lunt unit. Does this modded CaK unit allow you to capture any proms?
- Rusted
- Has thanked: 8168 times
- Been thanked: 1943 times
They really are amazing images Stu.
A well deserved SPOD.
Thanks, Brian. I’ve yet to give it a full road test, but this is certainly in the plan.MapleRidge wrote: ↑Sun Feb 26, 2023 12:23 am Outstanding images Stuart
- Has thanked: 612 times
- Been thanked: 404 times
Wonderful great results for sure, specially that Cak one the first one.
Now i have questions as it made me confused about things here and also asking to learn.
What is that Lunt CaK yellow filter? How come that CaK is yellow, i didn't see any Lunt CaK yellow filter around unless it is old filter discontinued.
What is Omega filter 393? How different is that from Baader K-Line filter as well? From where did you get that Omega filter then?
You mentioned the filters and the scope, but didn't mention the camera, which one?
-Tareq
-Tareq
Hi Tareq,TareqPhoto wrote: ↑Tue Mar 07, 2023 12:57 am Wonderful great results for sure, specially that Cak one the first one.
-Tareq
Thank you for your questions:
The 'yellow' filter is the blocking filter at the eyepiece of a Lunt CaK module. It works together with the silvered ITFs that allow 'blue' light through to narrow the bandwidth suitable for CaK line imaging.
The Omega 393 filter is similar to the Baader K-line, but has a narrower bandpass (2nm is claimed). I got it off ebay several years ago (2017/18 I think), but I don't think they are available anymore. There's some discussion on possible alternative filters here: viewtopic.php?t=39541
I used my Basler acA 2440-75 um for these images on a 2.7x Barlow (over sampled) to image disk quadrants that were stitched into a FD mosaic.
I hope these answers help.
Stu,Carbon60 wrote: ↑Tue Mar 07, 2023 8:02 amHi Tareq,TareqPhoto wrote: ↑Tue Mar 07, 2023 12:57 am Wonderful great results for sure, specially that Cak one the first one.
-Tareq
Thank you very much for your answers, it surely answered my questions, i hope i can find similar items you used to do for myself.
Tareq
