New Baader Calcium GEN-II 1.25" Filter
- Has thanked: 20435 times
- Been thanked: 10243 times
Spotted this today
https://www.firstlightoptics.com/solar- ... -lpfc.html
Interestingly it comes with ND3.8 film... That might have more interest than the filter itself
- Has thanked: 146 times
- Been thanked: 277 times
Re: New Baader Calcium GEN-II 1.25" Filter
Funny, you should mention it. I just received mine from TS today.
I hadn’t noticed that included the Baader 3.8. It is 150 mm I believe. Wish it were larger.
- Been thanked: 2713 times
Very interesting. Thanks for the news !
- Has thanked: 17667 times
- Been thanked: 8789 times
Sounds just like a Baader K-line filter, mine came with ND3.8 film too. It doesn't say what nm bandwidth it is.
- Has thanked: 2977 times
- Been thanked: 2082 times
Its 5nm. So a bit tighter compared to the old versions 8nm, supposed to have a bit better contrast.
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Hello,
This is a 5 nm filter with a peak transmission > about 90% :
https://www.baader-planetarium.com/en/c ... -lpfc.html
I would be incredibly surprised if there is much difference in contrast between old and new, it's a bit like their old and new continuum in that respect.
The transmission is higher than the original which makes it more appealing as a blocker in a homebrew CaK setup.
marktownley wrote: ↑Thu Mar 09, 2023 8:18 pmI would be incredibly surprised if there is much difference in contrast between old and new, it's a bit like their old and new continuum in that respect.
Yes, contrast wise i guess not much reason to get it if you have the old one.. its just a new revision.
Would be interesting to see cheaper narrowband filters with <1nm on the market.. should be just a matter of some years : )
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
In fact, there is a small gain on contrast when going to narrower band pass. I have :marktownley wrote: ↑Thu Mar 09, 2023 8:18 pmI would be incredibly surprised if there is much difference in contrast between old and new, it's a bit like their old and new continuum in that respect.
- an Edmund Optics, FWHM = 10 nm
- the "single stack" Baader K-line (one stack was broken ...), FWHM = 9 nm
- the original Baader K-line (double stack) FWHM = 7 nm,
- an Andover, FWHM 5 nm,
- an Antlia 3 nm (not mine), FWHM 3 nm.
There is for sure an increase of contrast when going from 10 nm to 3 nm. Big or small is a matter of appreciation ;-)
On the opposite there is no difference between the double-stack and single-stack continuum filters, since there is no line in the continuum (by definition ...).
A very good addition to the large list of near-UV filters currrently available would be a 430 nm FWHM 2 nm (G-band filter). Let's hope some manufacturer takes the challenge soon.
Another good addition would be a 1.5 A Ca II filter -hardcoated, 2-cavity) at reasonnable price. Which means having a large batch done.
bonjour à tous
avez vous une comparaison entre le antlia 3NM et le kline gen II
y a t il beaucoup de difference ?
Here is a comparison between the antlia 393-3 nm and the Edmund Optics :
http://astrosurf.com/viladrich/astro/so ... 4-10nm.jpg
The difference between the Antlia (FWHM = 3 nm) and a 5 nm filter (Baader or other) would be smaller. I'll show a picture of it when I'll get back some clear sky ;-)
Hi -
For those who are state-side, would you mind sharing where you purchased this new Baader filter ?
I see it available from several EU vendors but none in the USA.
Thank,
Philippe F.
Thank,
Philippe F.
- OlegLviv
- Has thanked: 881 times
- Been thanked: 907 times
Nice but you want say that Antlia 3nm better Baader Gen II? Because Antlia 3nm how brand I dont want buy....maybe Baader better?
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Oleg, i can recommend you the Antlia. Its quality is good enough for most of our purposes and its a bit narrower then the baader.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- OlegLviv
Thank you but bought Baader and waiting=)))
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
