Help me decide what to buy!
HAL
Been thanked: 133 times
Post by HAL »
Following on from my question about ERFs the other day...
I want to level up my imaging rig with some more aperture. I currently have a lovely Lunt LS60 and also a Quark which I am using with a Skywatcher 80ED. I will be keeping the Lunt for visual work and want a new scope for the Quark. I have a ZWO ASI174MM camera and Celestron AVX mount. Here's the options within my budget (around £2k).
1. Skywatcher Evostar 150 £639
Aperture 150mm
Focal length/ratio 1200mm f/8
Crayford focuser upgrade £185
ERF £963
Total £1787
Adv: aperture!
Dis: achromatic (though with the focuser upgrade I don't think this will matter for solar).
2. Skywatcher Evostar 120 £339
Aperture 120mm
Focal length/ratio 1000mm f/8.33
ERF £774
Total £1298
Adv: cheapest option but still significantly more aperture than the 80mm.
Dis: as above.
3. Skywatcher Evostar 120ED £1384
Aperture 120mm
Focal length/ratio 900mm f/7.5
ERF £774
Total £2158
Adv: apochromatic so can use for night time work as well, though this isn't the priority.
Dis: most expensive option.
4. Something else in this price range?
I would like to get the best imaging set-up I can within budget. I'd love to hear from anyone imaging with any of these telescopes + Quark + ERF.
Thanks for any help!
HAL
Dennis
Has thanked: 3053 times
Been thanked: 2151 times
Re: Help me decide what to buy!
Post by Dennis »
what are your imaging goals / preferences?
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
pupak
Has thanked: 4376 times
Been thanked: 3971 times
Post by pupak »
The Celestron AVX mount and the IMX174 camera are the most decisive for your choice. The assembly excludes the 150/F8 because it does not have the necessary stiffness.
That's why he chose them:
3. Skywatcher Evostar 120ED + Baader TZ4, or TV4x PMT 2". With this setup, you will be able to photograph details in good quality. It would be ideal to replace the IMX174 camera with a IMX432.
HAL
Post by HAL »
Thanks for these responses.
Dennis, I would like more resolution and more close-up views in general and possibly to move into some animations.
Pupak, the set-up with the 150mm would be well within the stated payload capability of the AVX, I know that in practice you can't go right to the limit. I wonder what you feel the limit is?
pupak
Post by pupak »
It's not just about weight, it's about length and torque. The picture shows my AR150/F8, which is 160 cm tall and weighs 15 kg with equipment. I have it on a backlash-free EQ-HD mount, and even that has something to do with it when the wind blows. That's my experience.
AR150/F8
AR150/F8
EQ HD mount kopie.jpg (276.07 KiB) Viewed 344 times
Dennis
Post by Dennis »
HAL wrote: Sun Mar 19, 2023 9:46 am Thanks for these responses.
Ok, then i would go with the 150mm f/8 achromat if you think seeing will support it.
Idk about the mount, but as pupak said, its not only about the weight but the length of the scope. I had a similar scope on a Ioptron az mount pro (15kg max payload specification) and it was shakey but worked. I kept the scope at minimum weight (~ 7.2 kg without dewcap and finder scope, no focuser upgrade). I used a D-ERF.
Balance is very important and doesnt leave much room for inbalance, that you have to keep in mind.
I also used a good diagonal to reach focus and not have the whole thing too long.
Triband C9.25
Barlows:
-2x TMB 1.8x
pupak
Post by pupak »
If you want to run an AR150/F8 on your mount, choose a lightweight lattice design. Not only will the weight be saved, but the area for the influence of the wind will be significantly reduced. That's how the 150/F15 can be handled.
AR150/F15
AR150/F15
Has thanked: 20738 times
Been thanked: 10432 times
I'd go for #1
solarchat
Site Admin
Site Admin
Has thanked: 84 times
Been thanked: 1373 times
Post by solarchat »
I'd go with #1, also.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
HAL
Post by HAL »
Thanks for the thoughts everyone. I think I am leaning towards #1, though I take on board the comments about tube length and balancing.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
I go also for the 150mm aperture.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
