March 15th Ha Session
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Good day everyone...
I managed to have my first solar session in over two weeks this past Wednesday and was away the balance of the week for work which delayed processing and posting. I processed the images while I was boiling sap at the bush yesterday to get caught up ;) This was a short session over lunch and not a lot of time to use more that the Lunt LS80T scope to image. First views at the eyepiece showed some nice activity with many filaments/AR's and and couple of impressive proms as well.
The first image is a full disk composite taken with the ASI1600MM camera+1.6x barlow through he DS Lunt LS80T/LS75FHa/B1800HJa solar scope:
With limited time, I switched to the ASI174MM camera and 3x telextender to image in slightly higher resolution, and was able to assemble mosaics of the norther and southern disk:
These last images are the larger proms that were found along the western limb:
I would have like to spend more time to image in greater detail but I was glad that I took the time to get these.
pupak
Has thanked: 4376 times
Been thanked: 3974 times
Re: March 15th Ha Session
Post by pupak »
Very nice discs and detailed pictures of proms.
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
A great set of images, Brian.
Very nice.
Petrus
Has thanked: 1578 times
Been thanked: 747 times
Post by Petrus »
An impressive set of captures Brian!
~ Petrus ~
Flickr
Has thanked: 17813 times
Been thanked: 16951 times
Post by DeepSolar64 »
Nice work, Brian!
arnedanielsen
Has thanked: 6276 times
Been thanked: 7294 times
Post by arnedanielsen »
Looking good!
Thanks for sharing, Brian!
Arne
Arne
Has thanked: 17925 times
Been thanked: 8893 times
These are fabulous Brian, I'm glad you got to see these beautiful prominences :bow :hamster: keep up the good work in the sugar bush :)
Thanks for all of your positive feedback and support on the images...always appreciated :bow
KMH
Has thanked: 657 times
Been thanked: 765 times
Post by KMH »
Beautiful results, Brian!
Kevin
DavidP
Has thanked: 147 times
Been thanked: 290 times
Post by DavidP »
Brian. Your full disk composite is masterful. Well done.
How many panels were used?
Kevin and David...
Thanks for your feedback...very much appreciated :bow
David, the image is a composite of separate full disk and limb exposures but not a mosaic of multiple frames. Not as masterful as it may seem, but thanks ;)
