March 20 2023. Spring Equinox!
- Has thanked: 17860 times
- Been thanked: 17003 times
My visual session time was from 15:04 until 15:55 UTC. The skies are clear with below average seeing and the temperature is 38F ( 3.3C ) at 15:30 UTC.
Orion 70mm Solar Telescope. 25x and 50x. ( WLC )
I can see twelve regions of activity on the photosphere but this makes it sound more impressive than it actually is. Most of it is really small spot groups or faculae from dying out groups. However four of these are nice areas. Five of these are in the northern hemisphere with three of these being numbered on the SolarMonitor images. Six are seen in the southern hemisphere. SM has them all labeled.
AR13260 is seen in the NE quadrant as a structured spot with a pore just south of it. Both are surrounded by faculae. I can also see faculae SE of the region, very near the limb. Could this be a new system I wonder? East of AR13260 lies AR13258. I can see it only as three pores in a line. Two are a bit easier to see than the third which is in the east of the line. Just NW of AR13258 lies a tiny hazy area. I can barely see it at 50x. It's a small group of very tiny pores that I cannot resolve. Well south of AR13258 lies a single lone pore. Near the NW limb I see two patches of faculae. One of these belongs to AR13252 but the SM image doesn't clearly show which facula it is since it is labeled between the two. I see no spots or pores here.
I see a large scattered patch of faculae near the SW limb. SolarMonitor images show it to be what remains of the complex of AR13249-50-51. I see one large pore here. I see nothing of AR13255 to the NE on the equator. The triple complex of AR13256-57-59 looks splendid in the SE quadrant. AR13256 shows itself as a nice structured spot showing it's umbra and penumbra easily. Five pores can be seen in it's immediate vicinity with a couple of more tiny difficult ones further SE that are visible during moments of better seeing. The center of the complex shows a small spot and a pore with the pore being difficult to see. The two close together spots of AR13257 show their umbra penumbra form easily. AR13259 shows itself as an E-W grouping of spots and pores surrounded by faculae. The two easternmost spots are the most prominent. In fact all of these active regions show visible faculae.
The fine granulation of the solar disc is visible but is not overly apparent.
Coronado SolarMax II 60 DS. 16x and 25x. ( 656.28nm )
I can see eight active regions in the Ha chromosphere today. Three in the northern hemisphere with at least two being labeled and five in the southern hemisphere with four of these showing number labels.
AR13260 in the NE quadrant shows itself as a spot and subtile plage with filaments surrounding it. A larger filament is seen well to the NW. Well west of AR13260, AR13258 appears as a bright etching in the chromosphere! It's beautiful to behold. Looking at the SpaceWeatherLive GOES satellite X-Ray graph I see a slow rolling curve that may indicate a slow-blow C-Class flare. It looks like it may have peaked at C4.4. Despite the low magnitude it looked quite impressive! An easy line of broken filaments lies just N-NW of this bright etching. More filaments are seen across the CLM from AR13258 and beyond that a double plage that may be associated with AR13252.
GONG Cerro Tololo Ha shows five tiny plage disturbances in the SW quadrant but I could see only two of them. A tiny one in the far SW above a couple of filaments and NNE of it another tiny one that is associated with AR13255. This one is at or on the equator. These two were not easy to find/see. The AR13256=57-59 complex in the SE quadrant are easy to see as three bright interconnected plages with at least four spots visible. Several filaments are seen within the region with the most prominent being just east of the spot of AR13256. Another fairly easy one is seen near the limb east of AR13259. A couple of filaments are also seen well north of AR13259.
The mottling of the chromosphere is easily seen.
Happy Spring Equinox!!
- Been thanked: 8907 times
Re: March 20 2023. Spring Equinox!
Oh, yeah. I thought that too!
- Has thanked: 3321 times
- Been thanked: 1907 times
- rigel123
- Has thanked: 8587 times
- Been thanked: 8822 times
Nice report James, that prom on the Western Limb was a dilly too!
I did see it but it was faint in doublestack. I forgot to enter it in the post!!
- Petrus
- Has thanked: 1597 times
- Been thanked: 769 times
Nice report, must have been a great session!
~ Petrus ~
Flickr
Flickr
- Has thanked: 9327 times
- Been thanked: 6163 times
Thanks and welcomes, Petrus and Franco.
- Been thanked: 4881 times
Thanks for the report James, looks you had a lovely observing day.
Thanks Maurits. I just completed another. I'll post the results shortly.
- Been thanked: 4981 times
James:
Thanks for the report.
Best regards and beautiful setup.
Thanks and you are welcome, Mr. Roel.
