Wow, really great time lapse Brian. The colours are beautiful!MapleRidge wrote: ↑Sat Mar 25, 2023 2:03 am Hi all...
I processed 23 photos of the aurora taken between 2:54 and 3:00 UT…all 5 second exposures with the Canon 60Da/8mm, f3.5 lens. I had to re-size them quite a bit to get the animation down to a reasonable size to post.
I think I started to take photos near the middle of the peak display...I had a few before this started but moved the camera and they do not match up with the others. These were some of the test shots to figure out the exposure which makes them harder to add in.
The video is available on my Flickr account:
https://www.flickr.com/photos/185395281 ... ateposted/
March 24th Aurora
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
Re: March 24th Aurora - Animation added
Clare & Peter
- Averton
A large coronal hole has moved across the Sun this week to the point that it is facing Earth.DeepSolar64 wrote: ↑Sat Mar 25, 2023 5:49 am What event on the Sun caused this solar storm? I know of no X-Class flare caused CME.
https://www.livescience.com/enormous-ho ... ras-friday
https://www.businessinsider.com/coronal ... rth-2023-3
Clare & Peter
- Been thanked: 4427 times
Mark and Clare & Peter...
Thanks for your comments on the image and animation
Stuart, thanks for pulling the additional data together too. It was a relatively short lived show form what I could tell visually...and my photos only covered 6 minutes of it (seemed much longer). The diffuse glow was active for at least a half hour before...maybe longer but I wasn't out looking.
I knew there was a coronal hole, but had no idea it was going to trigger an event like this and since there hadn't been a flare/CME I figured the coronal hole was the source (plus close to the equinox).
- Has thanked: 8559 times
- Been thanked: 8290 times
The solar wind from the coronal hole hadn’t arrived at the time of the event. It is due today (25th).
- Has thanked: 17853 times
- Been thanked: 16996 times
The coronal hole was certainly positioned right to get us on March 22. If the 24th event was not caused by the coronal hole then what caused it?
When I get a chance I'll have to research it.
I thought this hole had been active for many days, though closer to the SE limb than its current position.
- Has thanked: 387 times
- Been thanked: 635 times
That is fantastic ! The last aurora visible from northern italy (I am at 45 north) was in december 1989 close to the solar maximum. I was just a child at that time, but I remember many pictures of the red sky before dawn. Our latitude is too low to get the green ribbons, but it was definitely possible to observe tge red glow
Hi James,DeepSolar64 wrote: ↑Sat Mar 25, 2023 3:45 pm The coronal hole was certainly positioned right to get us on March 22. If the 24th event was not caused by the coronal hole then what caused it?
Possibly an unseen close encounter with a CME according to Spaceweather.com There’s quite a lot of uncertainty about this.
- nicspenceryork
- Has thanked: 6034 times
- Been thanked: 1310 times
Thanks Nic
Good displays that this one were long overdue
