Inspecting a Used Scope
- The Sun?
- Has thanked: 12 times
- Been thanked: 11 times
Hi all
First time on the forum, it's great to be here.
I have agreed to buy a second hand Coronado Solarmax III 70mm scope and I am arranging a time for an inspection. I have not looked through a solar scope since I had a PST more than ten years ago. As a complete newbie, what should I be looking out for when I inspect the scope?
I look forward to hearing from you.
Paul
Paul
Paul
82mm Binocular Telescope
Omegon Kollosus Parallelogram Mount
15X70 Oberwerk Binoculars
10x50 Pentax Binoculars
8x32 Hawke ED Binoculars
Various Eyepiece Sets
Re: Inspecting a Used Scope
Welcome to this forum Paul.
Look very careful to inspect the etalon so you don't have scratches or any damages ... and if the scope is original without any modifications.
- Has thanked: 9723 times
- Been thanked: 5773 times
Also check if there is rust on the blocking filter.
A very warm and sunny welcome Paul. The fact you are GOING for an inspection in person is the best thing you can do. Can you time your visit for a sunny day? It would be very advantageous to actually have a view through the scope, in fact this is the best test of all. Do you see features on the surface, is the contrast of these features even across the disc. Can you see prominences. This is key, if the owner can only show you a dim view of a white light looking Sun then there is a serious problem, don't buy!
Let us know how you get on.
- The Sun?
Thanks for the advice and the warm welcomes.
I will certainly take all your advice on board when I get to inspect the scope.
Alexandra, living in Ireland, as in the UK, sunny days can be as rare as hen's teeth, fingers crossed for a convenient one soon.
Paul
Paul
Paul
- Been thanked: 10487 times
Has the original owner got any images they can share taken through it?
- Has thanked: 17853 times
- Been thanked: 16995 times
Definitely look through the instrument first if you can.
Good luck on your " new " scope. I hope all goes well with it. I have two SolarMax II scopes and I hear the SolarMax IIIs are better but strangely I see almost none used here on SolarChat.
- The Sun?
Hi James
I have browsed the Web quite a bit and there appears to be a difference of opinion on the quality of the Solarmax III. Maybe the lack of second hand units on the site is a good sign that they are quality. The seller already has a Lunt 50mm and a 60mm and is trimming the herd. I will get an idea when I finnaly get to look through it.
Paul
Paul
Paul
- The Sun?
Hi James
Can I ask you about the Skywatcher AZ-GTI mount you have on your profile? If I purchase the Coronado, I was considering this mount or the dedicated Solarquest mount, would you recommended the AZ-GTI?
Paul
Paul
Paul
Overall I do like the AZ-GTI. It's small, portable and sturdy. It's drawbacks are the tripod needs a wider stance since the Coronado is heavy for it's size and with it mounted to the side off center it could be disastrously overturned if not careful. I typically use the AZ-GTI with the lighter Orion70 or AstroTech AT72EDII Vs the SMII60. Also, at least on mine, the tracking is not that great. I need to buy a hand controller for mine. I prefer that to using the phone via an app.
I called Sky-Watcher concerning the tracking. They recommended the SolarQuest for the Sun. They said it had an additional encoder to aid in better tracking of the Sun.
- The Sun?
Since I agreed to buy the scope, five days ago, it has not stopped raining. Are the gods trying to tell me something?
Paul
The clouds somehow know when an observer buys new equipment. It draws them like a shark to blood!
Paul,
Are you an imager or a visual observer, or both? While I do dabble in basic imaging I am first and foremost a visual observer.
- The Sun?
Hi James
Purely visual, I dabbled in astrophotography in the past, but all that post processing was more than I could handle. I perform some sketching and I am hopeful of pursuing some solar sketching.
Paul
Paul,
Though I do sometimes image stack from short AVI files, most of my imaging work is single frame imaging due to the simple mounts I use which are better suited to the visual work I am used to. In the past I have used mostly GIMP and Paint.net to edit/process my images but am now trying to learn how to use imPPG and PhotoShop for sharpening and editing. Like you I just do not have the time many spend doing all that processing work. Maybe when I retire in a few years! I'll admit, I tend to keep things simple but with imaging that's a disadvantage. Look at the images here that people spend the extra time and effort on to get it right. They are astounding!
There is something nearly magical for me about seeing these details visually with my own eyes. I don't ever see imaging ever replacing visual for me though imaging will certainly support my visual work. And in my opinion, accurate sketches are the best way to document the visual view. I can't draw worth a flip so I use descriptions. It works but people usually understand better when images are involved so I use professional images as guides at the scope and as something for others to see and compare my descriptions against. They also help me remember things as well but I must also remain vigilant to describe only what I see in the scope and not what the image shows. The images only support my work, what I see in the scope is my actual observations.
I hope I have not confused or bored you. Welcome to SolarChat and good luck with that Coronado!
