Late sun images today 28 March 2023
- Averton
- Has thanked: 3303 times
- Been thanked: 2312 times
So much for sunny Australia. It is now exactly 2 months since we last had a proper solar session with clear skies and no interruptions. Today didn't disappoint in continuing our run of ordinary solar imaging. It was forecast to rain late this afternoon, instead there was a small break in the clouds. We deliberated whether it would last long enough to grab an image or two but decided to try. It was only just. We grabbed a couple of videos between clouds with seeing averaging no better than 3 arc seconds. To amuse ourselves while waiting for this La Nina weather phenomenon to finally break up and leave our country, we did a time lapse between the last couple of images.
First a two panel mosaic in Ha. We had images from the 22, 25 and today for the time lapse. Then a full disk in 393nm. We only had an image from the 22 and today for the time lapse.
Clare & Peter
- rigel123
- Has thanked: 8316 times
- Been thanked: 8544 times
Re: Late sun images today 28 March 2023
Nice disks. The regions in the north and south are wonderfully depicted. It’s almost like two rivers of activity are like belts on the disk.
- Ibbo
- Has thanked: 2438 times
- Been thanked: 1650 times
- Been thanked: 4787 times
- Has thanked: 17581 times
- Been thanked: 16697 times
Agreed! Very nice discs. The Sun does indeed have belts. It always reminds me of it’s smaller orbital companion. Jupiter.
- Averton
- daniele_bonfiglio
- Has thanked: 586 times
- Been thanked: 576 times
Hi Clare and Peter, very nice session indeed! By the way, what do you mean by "DS60 - DS L40" ?
Best,
Daniele
Best,
Daniele
Solar scopes: Daystar Solar Scout DS 60/930
80mm f6 achromatic refractor with Daystar Quark from the Solar Scout
Scope: Skywatcher Maksutov-Cassegrain 127/1500
Mount: Skywatcher AZ-GTi
Camera: Fujifilm X-T30
Instagram: @daniele.bonfiglio.astropics
- Has thanked: 9145 times
- Been thanked: 6026 times
The K-line image and animation is really nice too.
- Averton
Thanks Danieledaniele_bonfiglio wrote: ↑Wed Mar 29, 2023 9:09 am Hi Clare and Peter, very nice session indeed! By the way, what do you mean by "DS60 - DS L40" ?
Best,
Daniele
DS60 = Daystar Solar Scout 60mm
DS = double stacked
L40 = Lunt 40mm etalon, front mounted with a custom 3D printed adapter.
The set up is as per this picture.
Clare & Peter
- Averton
- daniele_bonfiglio
Thank you for the explanation, Claire and Peter. So the Lunt etalon works even without any optic element in front of it? I didn't know...Averton wrote: ↑Thu Mar 30, 2023 7:29 amThanks Danieledaniele_bonfiglio wrote: ↑Wed Mar 29, 2023 9:09 am Hi Clare and Peter, very nice session indeed! By the way, what do you mean by "DS60 - DS L40" ?
Best,
Daniele
DS = double stacked
By the way I also have a Daystar Solar Scout 60mm (version with the "unremovable" quark unit) and I see from old posts that you 3D printed an adapter to put the quark unit in a standard 2" focuser... this is very nice solution, I would also need something like this!
Best, Daniele
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
- Has thanked: 8418 times
- Been thanked: 8165 times
It’s really frustrating when the weather doesn’t cooperate and you have to go fishing in the cloud gaps. Nice results from your perseverance.
- Averton
Our Solar Scout is also the "unremovable" Quark unit so we had to design our own adapter as you noted. It doesn't go directly into a 2" focuser. Our adapter has an M42 thread on it which we screw into a 2" extension tube as per pictures. We are happy to provide the stl file for our adapter if that is of any help to you.daniele_bonfiglio wrote: ↑Thu Mar 30, 2023 8:13 amThank you for the explanation, Claire and Peter. So the Lunt etalon works even without any optic element in front of it? I didn't know...Averton wrote: ↑Thu Mar 30, 2023 7:29 amThanks Danieledaniele_bonfiglio wrote: ↑Wed Mar 29, 2023 9:09 am Hi Clare and Peter, very nice session indeed! By the way, what do you mean by "DS60 - DS L40" ?
Best,
Daniele
DS = double stacked
Best, Daniele
Clare & Peter
- Averton
- daniele_bonfiglio
Yes, please! Do provide the file for the 3D printed adapter. A friend of mine has a 3D printer and I will ask him to have a look at the file. Thanks a lot!Averton wrote: ↑Thu Mar 30, 2023 10:26 am Our Solar Scout is also the "unremovable" Quark unit so we had to design our own adapter as you noted. It doesn't go directly into a 2" focuser. Our adapter has an M42 thread on it which we screw into a 2" extension tube as per pictures. We are happy to provide the stl file for our adapter if that is of any help to you.
Regards, Daniele
- Averton
Daniele, here is the stl file. Had to zip it for the forum as it doesn't allow stl files.daniele_bonfiglio wrote: ↑Thu Mar 30, 2023 12:21 pmYes, please! Do provide the file for the 3D printed adapter. A friend of mine has a 3D printer and I will ask him to have a look at the file. Thanks a lot!Averton wrote: ↑Thu Mar 30, 2023 10:26 am Our Solar Scout is also the "unremovable" Quark unit so we had to design our own adapter as you noted. It doesn't go directly into a 2" focuser. Our adapter has an M42 thread on it which we screw into a 2" extension tube as per pictures. We are happy to provide the stl file for our adapter if that is of any help to you.
Regards, Daniele
You need to slice the threaded section at 0.1mm layer height.
Clare & Peter
- daniele_bonfiglio
Thank you very much Clare and Peter!
I will ask my friend to have a look in the next few days, and I will let you if I have any question.
Best,
Daniele
- daniele_bonfiglio
Dear Clare and Peter, sorry for the naive question: why you opted for a M42 thread? Most of the 2" extension tubes have M48 threads of I'm not wrong... Just in case, it would be possible to modify your file putting a M48 thread instead of a M42 one? Thanks a lot and sorry for the trouble!Averton wrote: ↑Fri Mar 31, 2023 10:20 amDaniele, here is the stl file. Had to zip it for the forum as it doesn't allow stl files.daniele_bonfiglio wrote: ↑Thu Mar 30, 2023 12:21 pmYes, please! Do provide the file for the 3D printed adapter. A friend of mine has a 3D printer and I will ask him to have a look at the file. Thanks a lot!Averton wrote: ↑Thu Mar 30, 2023 10:26 am Our Solar Scout is also the "unremovable" Quark unit so we had to design our own adapter as you noted. It doesn't go directly into a 2" focuser. Our adapter has an M42 thread on it which we screw into a 2" extension tube as per pictures. We are happy to provide the stl file for our adapter if that is of any help to you.
Regards, Daniele
Scout quark to M42 adapter.stl.zip
Best,
Daniele
- Been thanked: 8793 times
Superb images Clare & Peter
How is the arm Clare? hopefully nearly healed.
- Peterm
- Has thanked: 1733 times
- Been thanked: 1488 times
Nice set of images Peter & Clare. The images of your setup are very instructive. Hoping to make some of my own images and animations again soon.
BOSS team: www.bosssupernova.com
- Averton
Thanks Alexandra
My shoulder is improving but still has a long way to go to get full range of movement back again. It's a very long slow process but I am making gains each day.
Clare & Peter
- Averton
Thanks Peter
Have missed your posts recently. Hope to see some soon!
Clare & Peter
- Averton
Hi Daniele,daniele_bonfiglio wrote: ↑Sat Apr 01, 2023 4:44 pmDear Clare and Peter, sorry for the naive question: why you opted for a M42 thread? Most of the 2" extension tubes have M48 threads of I'm not wrong... Just in case, it would be possible to modify your file putting a M48 thread instead of a M42 one? Thanks a lot and sorry for the trouble!Averton wrote: ↑Fri Mar 31, 2023 10:20 amDaniele, here is the stl file. Had to zip it for the forum as it doesn't allow stl files.daniele_bonfiglio wrote: ↑Thu Mar 30, 2023 12:21 pm
Regards, Daniele
Best,
Daniele
We use M42 T threads as all of our ZWO cameras have that thread. We do not have a camera or adapter for M48. Unfortunately its not really practical to modify the CAD file without having an adapter to test a print with. This is because, unlike CNC, FDM 3D printing has shrinkage which has to be determined by experiment so without a test piece its not possible to make a model. Sorry about that.
Clare & Peter
- daniele_bonfiglio
Hi Clare and Peter, thank you it's okay anyway, I think I have found on the internet an extension tube that should work well with your 3D printed adapter. It has an M42 thread on the quark side and a 2” nose with a M48 thread on the telescope side for the required IR cut filter. This is the picture... What do you think?Averton wrote: ↑Sun Apr 02, 2023 12:54 pmHi Daniele,daniele_bonfiglio wrote: ↑Sat Apr 01, 2023 4:44 pm Dear Clare and Peter, sorry for the naive question: why you opted for a M42 thread? Most of the 2" extension tubes have M48 threads of I'm not wrong... Just in case, it would be possible to modify your file putting a M48 thread instead of a M42 one? Thanks a lot and sorry for the trouble!
Best,
Daniele
Daniele
Clare,
I’ll remember you in my prayers.
- Averton
Hi Daniele,daniele_bonfiglio wrote: ↑Sun Apr 02, 2023 1:50 pmHi Clare and Peter, thank you it's okay anyway, I think I have found on the internet an extension tube that should work well with your 3D printed adapter. It has an M42 thread on the quark side and a 2” nose with a M48 thread on the telescope side for the required IR cut filter. This is the picture... What do you think?Averton wrote: ↑Sun Apr 02, 2023 12:54 pmHi Daniele,daniele_bonfiglio wrote: ↑Sat Apr 01, 2023 4:44 pm Dear Clare and Peter, sorry for the naive question: why you opted for a M42 thread? Most of the 2" extension tubes have M48 threads of I'm not wrong... Just in case, it would be possible to modify your file putting a M48 thread instead of a M42 one? Thanks a lot and sorry for the trouble!
Best,
Daniele
Daniele
That looks like it should do the job.
Clare & Peter
- daniele_bonfiglio
Hi Clare and Peter,
thank you again for sharing the stl file!
I finally managed to get the adapter 3D printed based on it. This is the result, the material is ABS.
May I ask a couple of questions:
1) what is the size of the 3 screws to be used to hold the quark?
2) do you confirm that I also need a 2" IR cut filter for use on a 80 mm refractor? I see you have the ZWO... I have found on Amaz... a similar 2" IR-UV cut filter by Svbony: do you think this will do the job as well?
Daniele
Daniele
- Has thanked: 6181 times
- Been thanked: 7142 times
Nice to see Clare and Peter.
Great to read that your shoulder is every day a bit better.
- Averton
Hi Daniele,daniele_bonfiglio wrote: ↑Fri Jun 09, 2023 2:56 pm Hi Clare and Peter,
Daniele
Your printed adapter looks good.
We used M4 nylon screws to retain the Quark.
From the DayStar manual
"To prevent damage, we recommend using an Energy Rejection Filter on telescopes of 80mm aperture or more, or when tracking the Sun for long periods. This can be a UV/IR cut filter mounted before the diagonal, or a full aperture red or yellow glass ERF mounted in front of the telescope."
So we use the 2" IR/UV cut filter even with our 72ED as well as our K102.
SVBony filters seem quite reasonable so we can see no reason why it wouldn't do the job.
Looking forward to seeing your pictures
Clare & Peter
- daniele_bonfiglio
Thank you very much Clare and Peter! Actually I have to get a telescope before taking any picture! I am thinking of a 80mm f6 achromat.Averton wrote: ↑Sat Jun 10, 2023 11:48 amHi Daniele,daniele_bonfiglio wrote: ↑Fri Jun 09, 2023 2:56 pm Hi Clare and Peter,
Daniele
Best,
Daniele
