Thanks Peter
Have missed your posts recently. Hope to see some soon!
Thanks Peter
Hi Daniele,daniele_bonfiglio wrote: ↑Sat Apr 01, 2023 4:44 pmDear Clare and Peter, sorry for the naive question: why you opted for a M42 thread? Most of the 2" extension tubes have M48 threads of I'm not wrong... Just in case, it would be possible to modify your file putting a M48 thread instead of a M42 one? Thanks a lot and sorry for the trouble!Averton wrote: ↑Fri Mar 31, 2023 10:20 amDaniele, here is the stl file. Had to zip it for the forum as it doesn't allow stl files.daniele_bonfiglio wrote: ↑Thu Mar 30, 2023 12:21 pm
Yes, please! Do provide the file for the 3D printed adapter. A friend of mine has a 3D printer and I will ask him to have a look at the file. Thanks a lot!
Regards, Daniele
You need to slice the threaded section at 0.1mm layer height.
Scout quark to M42 adapter.stl.zip
Best,
Daniele
Hi Clare and Peter, thank you it's okay anyway, I think I have found on the internet an extension tube that should work well with your 3D printed adapter. It has an M42 thread on the quark side and a 2” nose with a M48 thread on the telescope side for the required IR cut filter. This is the picture... What do you think?Averton wrote: ↑Sun Apr 02, 2023 12:54 pmHi Daniele,daniele_bonfiglio wrote: ↑Sat Apr 01, 2023 4:44 pm Dear Clare and Peter, sorry for the naive question: why you opted for a M42 thread? Most of the 2" extension tubes have M48 threads of I'm not wrong... Just in case, it would be possible to modify your file putting a M48 thread instead of a M42 one? Thanks a lot and sorry for the trouble!
Best,
Daniele
We use M42 T threads as all of our ZWO cameras have that thread. We do not have a camera or adapter for M48. Unfortunately its not really practical to modify the CAD file without having an adapter to test a print with. This is because, unlike CNC, FDM 3D printing has shrinkage which has to be determined by experiment so without a test piece its not possible to make a model. Sorry about that.
Clare,
Hi Daniele,daniele_bonfiglio wrote: ↑Sun Apr 02, 2023 1:50 pmHi Clare and Peter, thank you it's okay anyway, I think I have found on the internet an extension tube that should work well with your 3D printed adapter. It has an M42 thread on the quark side and a 2” nose with a M48 thread on the telescope side for the required IR cut filter. This is the picture... What do you think?Averton wrote: ↑Sun Apr 02, 2023 12:54 pmHi Daniele,daniele_bonfiglio wrote: ↑Sat Apr 01, 2023 4:44 pm Dear Clare and Peter, sorry for the naive question: why you opted for a M42 thread? Most of the 2" extension tubes have M48 threads of I'm not wrong... Just in case, it would be possible to modify your file putting a M48 thread instead of a M42 one? Thanks a lot and sorry for the trouble!
Best,
Daniele
Daniele
Hi Daniele,daniele_bonfiglio wrote: ↑Fri Jun 09, 2023 2:56 pm Hi Clare and Peter,
thank you again for sharing the stl file!
I finally managed to get the adapter 3D printed based on it. This is the result, the material is ABS.
May I ask a couple of questions:
1) what is the size of the 3 screws to be used to hold the quark?
2) do you confirm that I also need a 2" IR cut filter for use on a 80 mm refractor? I see you have the ZWO... I have found on Amaz... a similar 2" IR-UV cut filter by Svbony: do you think this will do the job as well?
Daniele
Thank you very much Clare and Peter! Actually I have to get a telescope before taking any picture! I am thinking of a 80mm f6 achromat.Averton wrote: ↑Sat Jun 10, 2023 11:48 amHi Daniele,daniele_bonfiglio wrote: ↑Fri Jun 09, 2023 2:56 pm Hi Clare and Peter,
Daniele
Your printed adapter looks good.
We used M4 nylon screws to retain the Quark.
From the DayStar manual
"To prevent damage, we recommend using an Energy Rejection Filter on telescopes of 80mm aperture or more, or when tracking the Sun for long periods. This can be a UV/IR cut filter mounted before the diagonal, or a full aperture red or yellow glass ERF mounted in front of the telescope."
So we use the 2" IR/UV cut filter even with our 72ED as well as our K102.
SVBony filters seem quite reasonable so we can see no reason why it wouldn't do the job.
Looking forward to seeing your pictures
