ImPPG version 1.9.1-beta
GreatAttractor
Has thanked: 762 times
Been thanked: 758 times
Post by GreatAttractor »
ImPPG v. 1.9.1-beta is out with the following bug fixes:
  • Invalid channel order when loading 8-bit RGB images
  • Cannot enable adaptive unsharp mask
  • Crash when using adaptive unsharp mask in CPU & bitmaps mode
Homepage: https://greatattractor.github.io/imppg/
Download: https://github.com/GreatAttractor/imppg ... 1.9.1-beta
My software:
My images
Has thanked: 18921 times
Been thanked: 9265 times
Re: ImPPG version 1.9.1-beta
Thanks Filip,
I tried to use it but I can't open it, I get this error, any ideas?
ImPPG 2023-05-14 161819.png (340.06 KiB) Viewed 13745 times
Kind regards
GreatAttractor
I've just downloaded it and it ran fine, libcfitsio-3.dll is present in imppg-win64.zip. Can you try downloading again, unpacking to a fresh directory and running from there?
On another note: did you copy "imppg.exe" somewhere else (and renamed it "imppg 1.9.exe"?) It has to stay in the same folder as all the other files (DLLs, images etc.). However, it's fine to make a shortcut (link) to imppg.exe (e.g., on the Desktop).
My software:
My images
Radon86
Has thanked: 763 times
Been thanked: 665 times
Post by Radon86 »
Hi Filip/Great Attractor,
I have used ImPPG 1.9.1-beta or the latest version, and have noticed "Add Mask" option in the unsharp mask section.
Is this enablng mulitple unsharp masks to be applied ?
How do you create the mask on the sun or is it applied to the whole image ?
There is no option for a blend mode or mask layering order or am I missing something ?
Thanks!
Magnus
GreatAttractor
Yes, multiple unsharp masks can be created. They are applied sequentially; no plans currently for more elaborate blending options etc., but now that you mention it, I'll add "move up/down" buttons.
So far I've been using 2 masks at most; one for sharpening (amount > 1.0), and then one with a much smaller sigma for slight denoising (amount < 1.0).
My software:
My images
