Morning all,
Just after some advice re the use of this filter in a Solarmax 40mm.
As the erf in the diagonal has rusted its now been removed, and I'm intending to use the H Alpha filter behind the internal objective (see photos) is there anything else I need to be aware of?
I have flipped the filter so the metallic face is at the front.
Thanks for your help.
Solarmax 40 and Baader H Alpha 35mm CCD filter
- DSobserver
- Been thanked: 19 times
Re: Solarmax 40 and Baader H Alpha 35mm CCD filter
You mean you expect replacing the itf (and not erf) from the diagonal with this ha filter?
Visually it is dangerous!
Even if baader 35nm is similar to the erf that are not blocking ir as good as itf!
If itf is rusted then ask m’aider or beloptik for replacement!
- Bob Yoesle
- Has thanked: 540 times
- Been thanked: 807 times
The rusted ITF filter should only be replaced with the Maier ITF replacement filter, the BelOptik ITF replacement filter, or the BelOptik UV/IR block on KG3 filter.
- Has thanked: 9411 times
- Been thanked: 5571 times
Hi,As the erf in the diagonal has rusted its now been removed ...
You are mixing up things. ERF's do not rust but as others alreadyd said it is the ITF or blocking filter which is a completely different thing.
For Visual use this is dangerous, for photographic use it would be OK.
BTW, the ERF on your 40mm is the red glass on the front..
