solarmax 2 90 straight through blocking filter won't fit feathertouch
- Bojan
- Has thanked: 8 times
- Been thanked: 11 times
So I have the 90mm solarmax 2 with a straight through blocking filter.
I bought the right feathertouch focuser and adapted and well ... The feathertouch fits great onto the scope however the blocking filter doesn't screw on anywhere.
It doesn't screw onto the front of a 2" diagonal, or anything similar. Anyone have any experience with this or ideas on how to mount it safely ?
Thanks !
Thanks !
- received_573025898153090~2.jpeg (255.46 KiB) Viewed 447 times
- 20230515_161910~2.jpg (7.9 MiB) Viewed 447 times
Pre-Meade Solarmax40
SolarmxII DS90
Lunt 2" Wedge on ES 127mm Apo
SolarmxII DS90
- Been thanked: 16691 times
Re: solarmax 2 90 straight through blocking filter won't fit feathertouch
Hmm... It's too big to fit into the FeatherTouch? I have a BF15 diagonal type one. I am not familiar with how the straight-through is made.
- Bojan
The blocking filter is considerable smaller than the front of the focuser. It's the exact same diameter as the end of a 2" diagonal, but on the blocking filter the threads are female.DeepSolar64 wrote: ↑Wed May 17, 2023 4:55 am Hmm... It's too big to fit into the FeatherTouch? I have a BF15 diagonal type one. I am not familiar with how the straight-through is made.
I got quoted about 300$ for a custom adapter, it would take a lot of time to measure threads and program CNC machine.
- 20230515_160150~2.jpg (6.7 MiB) Viewed 397 times
- 20230515_160154~2.jpg (6.54 MiB) Viewed 398 times
SolarmxII DS90
SolarmxII DS90
Ok, Mr. Townley, it's time you chime in. You are good on stuff like this! :-)
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
Just for clarity:
What is the diameter of the exterior of the blocking filter?
Is it not a 2" push fit ?
- Bojan
It is same diameter as the nose of a 2" diagonal, but unsure how that helps to get a diagonal or eyepeices behind it
SolarmxII DS90
SolarmxII DS90
- Rusted
Once you have a standard dimension you open up all the possibilities of standard adapters, extenders and filter holders.
You haven't shown the complete unit. So it is difficult to see whether the entire length is 2" push fit. I think I can see a raised section.
Nor have you mentioned whether the focuser has a standard 2" push fit draw tube. One must presume it has.
Your starting point might be to discover what Coronado screws into that thread in the blocking filter.
Or [preferably] the one on the tail end? Is there one?
A millimeter rule, ruler or tape measure will give you a quick and rough idea of the female thread's diameter.
Or take it to a tool shop and borrow a vernier caliper from the display. You can buy a usable vernier caliper for small change.
Be gentle or you will damage the thread!
Once you have the thread diameter you start searching the astro websites for anything which will screw into it.
Those of us who mod telescopes usually have a drawer full of adapters and extenders. They cost a fortune but are essential to progress.
BTW: Your equipment will hold its value better if you avoid piling it on an untidy surface.
It also makes photography and identification of detail much easier. So other forum members can better help you.
For photography use a plain, neutral background. Normal, fawn, cardboard used for packaging [boxes] are ideal and cost nothing.
Frame the subject you want us to identify in good light. Not the rest of the room.
- Has thanked: 20424 times
- Been thanked: 10243 times
Won't it just screw onto the front of a 2" diagonal? Or, sit inside the EP holder of a 2" diagonal?
- Bojan
So I thought I was making some progress however no dice.
First picture is the BF, the adapter that attaches it to the helical focuser and the diagonal.
If you cannibalize the helical focuser you can make a nice long train that holds the BF30, adapter, cannibalized helical, and the diagonal. It's not great as I'm not sure the one thumb screw can hold the diagonal and the intended binoviewers.
However frustratingly, the silver piece is a 2" push size, and fits neatly into a 2" focuser or diagonal. However the black piece from the helical focuser does not. it must be a mm bigger.
Contacting Meade has been less than fruitful. I purchased some calipers and thread gauges to try and figure out the exact threads and then find an adapter.
SolarmxII DS90
SolarmxII DS90
- OlegLviv
- Has thanked: 881 times
- Been thanked: 907 times
Bojan hello!
Where is your ITF bloking filter?
Do you know why this BF dont have itf bloking filter inside?
- Screenshot 2023-05-24 195802.jpg (135.7 KiB) Viewed 231 times
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
Mounh: 2xSky Watcher AZEQ6
Baader D-ERF 160MM
2xBaader 1.25 GPC
2xLunt 50mm
Lunt Cak B1200
Coronado BF15
- Bojan
With the BF30 the itf is inside the BF. The diagonal just has a red/ir filter if memory serves
SolarmxII DS90
SolarmxII DS90
What do you need the small black threaded ring for?
