Interesting experiment in H-alpha on AR150/F24 21.05.
- Has thanked: 4379 times
- Been thanked: 3976 times
I modified one BF from the Quark combo into a T2 and tried to put it in front of the TZ2 today. Image quality has improved significantly. It was a big surprise for me. Next time I will try it on another telescope to verify that this solution is universal. In the attachment there are 10 stacked images, they are stretched without modifications and a standard processed image.
- ET1.jpg (239.45 KiB) Viewed 673 times
- stackk only
- s1.jpg (448.14 KiB) Viewed 677 times
- s1u.jpg (538.06 KiB) Viewed 677 times
- LK.jpg (2.03 MiB) Viewed 677 times
Re: Interesting experiment in H-alpha on AR150/F24 21.05.
Stretch another 30 stacked pictures.
- INX 432
- s2.jpg (422.66 KiB) Viewed 669 times
- Has thanked: 9319 times
- Been thanked: 6157 times
To avoid starting another thread, I'll add a few more of today's catches here.
- IMX432
- s4.jpg (192.69 KiB) Viewed 636 times
- IMX432
- s5.jpg (213.81 KiB) Viewed 636 times
- IMX432
- ss1.jpg (503.86 KiB) Viewed 636 times
- IMX432
- ss3.jpg (570.94 KiB) Viewed 636 times
- IMX432
- ss4.jpg (520.41 KiB) Viewed 636 times
- IMX432
- ss5.jpg (195.44 KiB) Viewed 636 times
- Has thanked: 6305 times
- Been thanked: 7324 times
Another set of great images, Petr!
Thanks for sharing,
Arne
Thanks for sharing,
Arne
- Ivan
- Has thanked: 3483 times
- Been thanked: 2263 times
- Has thanked: 3317 times
- Been thanked: 1907 times
Very nice.
Out looking at ERFs and Blocker filter temperature.
Lots of nice details in the proms visually. I switched to my closed non-dominant eye for more details briefly.
Cheers. Andrew.
Very nice.
Cheers. Andrew.
- KMH
- Has thanked: 658 times
- Been thanked: 772 times
Great results!
Are you using one of those strain wave mounts (at least that's what iOptron calls them) that doesn't require counterweights?
Kevin
Kevin
- Has thanked: 17853 times
- Been thanked: 16995 times
You are among our best here for high resolution closeup imagery. Thanks Pupak!
I make mounts with harmonic gearboxes myself. I use quality Japanese size 20 HD gearboxes, not Chinese size 17 copies.
The small mount will reliably support 20kg and handle a 2m giraffe (N200/ F10).
The only weakness is the tripod.
- Ross
- Has thanked: 546 times
- Been thanked: 574 times
spectacular
Daystar Quark cromosfera, 80ED Skywatcher, Player One Filtro ERF 1.25″ serie S per Quark Chromosphere, ASI174MM, Skywatcher AZEQ5, Baader Solar Continuum Filter, Baader Prisma di Herschel, Barlow 5x.
- banjo
- Has thanked: 2100 times
- Been thanked: 2878 times
- KMH
Wow - that's impressive!
Kevin
- Has thanked: 8559 times
- Been thanked: 8290 times
Awesome images, Petr.
How’s the hand?
How’s the hand?
- Been thanked: 10488 times
Very promising there Petr!
Thank you for your interest, Stu.
The surface of the hand is almost healed, but the 4 cm of duralumin that went in has done enough damage there that it will be weeks before the index finger is functional and it is possible that the damage to the joint will be permanent.
I'm going through a period where the nerve connections are being rewired inside, which is quite unpleasant and painful. It usually takes 14 days. I already have experience with it. It's not the first time I've played doctor.
You really needed a doctor, Petr.
I don't want to weed the sun topic here, but I don't have a medical facility within reach where I can safely entrust myself to the care of doctors. Although I only have 5 semesters of medicine, I think I can evaluate when I need a surgeon's intervention. I was very lucky that the duralumin didn't cut my tendons and break my bones. The energy must have been huge, as it also bruised the surrounding two fingers. No available doctor can fix a damaged joint. I would just risk an order of magnitude bigger problem than I have. I firmly believe that work rehabilitation will bear fruit and in two months the hand will be fully functional. You can work with it, and I probably won't play the guitar anymore, but I'll survive.
Petr
Petr,
Good luck in your healing. Doctors are certainly not equal everywhere and all are expensive. It's a good thing that you do have some medical training. That can be useful. I am glad you did not suffer any more damage than what you did.
Keep those awesome images coming. Your scopes and imaging skills are impressive.
