Uv/ir cut
alessbonsai
Has thanked: 516 times
Been thanked: 651 times
Uv/ir cut
Post by alessbonsai »
in WL with astrosolar, in front of the 540nm filter do I have to use a uv/ir filter? is the Baader filter suitable or do I have to use one in particular
PST coronado Mod
Planet 102 f11
Vixen 70/900 mod WL
Dennis
Has thanked: 3389 times
Been thanked: 2496 times
Re: Uv/ir cut
Post by Dennis »
It might give better results. Baader recommends a uv/ir cut filter for visual use with the 540nm filter and the shown bandpass ranges from 400nm-700nm. So i would try it out and see if a difference is there.
Triband C9.25
H-a: 2x Lunt40 rear mounted
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Has thanked: 18797 times
Been thanked: 9201 times
Re: Uv/ir cut
I usually do, the older versions of the Baader Continuum didn't block very far IR so tended to make imaging blurry. If you have one, use it anyway, it won't change anything if you don't need it but will make a huge improvement if you do need it :)
alessbonsai
Re: Uv/ir cut
i have the new version of the uv/ircut filter. I can mount the 1.25 filter directly on the nose of the camera … camera-filter540-barlowtv2x-uv/ir-herschel filter…
PST coronado Mod
Planet 102 f11
Vixen 70/900 mod WL
Has thanked: 21943 times
Been thanked: 11175 times
Re: Uv/ir cut
I would mount that uv/ir cut much higher up the optical train if you can
alessbonsai
Re: Uv/ir cut
I always get confused… at the top you mean near the sensor or the telescope? My doubt is, can a filter immediately after the sensor worsen the performance of the powermate or telecentric in general?
PST coronado Mod
Planet 102 f11
Vixen 70/900 mod WL
DavidP
Has thanked: 169 times
Been thanked: 389 times
Re: Uv/ir cut
Post by DavidP »
Generally, when we talk about before or after in an optical train we are referencing the path of light in time. So with a refractor, first is the objective lens, last is the detector.
It seems to be good practice to put the UV/IR filter closer to the refractor objective. The earlier you can reject heat causing energy, the better. This lessons the potential to build up heat in the system. When Mark says higher up, he means earlier in the incoming light path or closer to the refractor objective.
