Appalling wibbles and wobbles up there today , but with cloud approaching fast I kept pressing the shutter button and then selected 49 lovely frames from the 800 shot ...
I was seeing a small but distinct bright ring in the area between ARs 13311 and 13314 during capture , I'd love to know if that area was flaring , sadly SDO 304 is not caught up past midnight yet , the shots were taken between 07:30 and 07:45 UTC. My image shows it clearly when you zoom in ...
Sun in Whitelight 24th May 2023
- steveward53
- Has thanked: 1241 times
- Been thanked: 1503 times
Steve.
Day by day Solar album ... http://www.astrobin.com/users/steveward53/
Tal 100RS , ED80Pro , Mak180Pro.
HEQ5Pro , EQ3/2 , 14' pier.
Canon 1000D , SPC900NC Mono.
Scopium wedge - Baader ND3.8.
- Has thanked: 6305 times
- Been thanked: 7323 times
- steveward53
Re: Sun in Whitelight 24th May 2023
Thanks Arne ,
I was getting worried when I rejected the first 600 frames as unusable , and then found about forty-odd lovely crisp ones in the next set of 120 I went through ... and the clouds had already rolled over so I couldn't try again ...
Steve.
- SteveZ
- Has thanked: 149 times
- Been thanked: 143 times
Steve - Great set of WL full disk images.
Steve
Lunt LS80MT Single Stack
B1800 Blocking Filter
Lunt Herschel Wedge
Mallicam DS16M
AVX Mount
Steve
Lunt Herschel Wedge
Mallicam DS16M
AVX Mount
- rigel123
- Has thanked: 8576 times
- Been thanked: 8810 times
Great disks Steve! Checking SpaceWeather I see a flare at 8:00 UTC but not at the times you were imaging. It sure looks like flaring.
- Has thanked: 17853 times
- Been thanked: 16992 times
Steve,
Imaging at 540 and 430nm eight hours or so after you I did not pick up a ring around a spot in the western part of AR13311 as you did but did pick up some brighter areas in a couple of spots in the SE of AR13311. I won't go as far as saying they are white light flares but that area has been very active lately.
Nice images. Yours are a bit sharper than mine turned out to be.
- Has thanked: 20813 times
- Been thanked: 10487 times
A nice disk Steve!
