A Sunspot Is So Large Right Now You Can See It Without A Telescope
Solarscout
Has thanked: 9 times
Been thanked: 91 times
Post by Solarscout »
"A sunspot four times the size of the Earth is making its way across the Sun at the moment. The spot is so large you can see it without a telescope, though of course you should use protective equipment."
Sunspot AR3310, bottom right, should be visible without magnification.
https://www.iflscience.com/a-sunspot-is ... cope-69096
Anyone tried observing this without telescope or binoculars? did you look at it directly with solar glasses or other methods (projection, reflection on water...)?
Has thanked: 17807 times
Been thanked: 16940 times
Re: A Sunspot Is So Large Right Now You Can See It Without A Telescope
Post by DeepSolar64 »
I haven't tried just a filter but I am sure it's easily visible at 1x from past experience. It's sizable in my Lunt 8x32s.
Has thanked: 20732 times
Been thanked: 10427 times
Yes is easy naked eye with proper filtration.
