May 26 2023 Ca K closeups SS and DS
- Has thanked: 1283 times
- Been thanked: 1071 times
Hi all,
today I decided to make Ca K DS from two available standard Lunt filters, putting them close to each other with a little tilt, and compare it with SS. The resulting images were a bit dark, but acceptable. The noise level of 174 camera in the DS was normal to stack 100 frames. Fibrils began to appear in the dipole and penumbra area, and reverse granulation became more contrasting. I made the lighter SS images look like DS using the hdr Ps plugin, for comparison. The seeing was Ok for full aperture.
Setup: 120/1000, TV 5x, ASI174, Lunt1800 and Lunt600
Leo
Leo
- DS
- Sun 20230526-0716_7_cOPs_DS.jpg (797.66 KiB) Viewed 645 times
- SS
- Sun 20230526-0637_1_cOPstd SS.jpg (678 KiB) Viewed 645 times
- DS
- Sun 20230526-0718_1_cO2Pstd_DS.jpg (742.12 KiB) Viewed 645 times
- SS
- Sun 20230526-0636_3_cO3Pstd_SS.jpg (775.83 KiB) Viewed 645 times
- AR3311 3314
- Sun 20230526-0710_0_cOPs DS.jpg (722.94 KiB) Viewed 645 times
- Been thanked: 2725 times
Re: May 26 2023 Ca K closeups SS and DS
Very well done Leo !!
- rigel123
- Has thanked: 8663 times
- Been thanked: 8904 times
Excellent!
- Has thanked: 17960 times
- Been thanked: 17110 times
Leo,
These are really nice. The supergranulation is very easy to see. The images are sharp with nice contrast too.
- Has thanked: 3107 times
- Been thanked: 2206 times
Stunning images Leo and interesting comparison of ds and ss.
DS really seems to be worth upgrading to. How do you tilt the filters?
Triband C9.25
H-a: 1-2 Lunt40 rear mounted
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 6353 times
- Been thanked: 7411 times
Excellent images and a very nice comparison Leo!
Thanks for sharing,
Arne
Thanks for sharing,
Arne
- Petrus
- Has thanked: 1615 times
- Been thanked: 776 times
Fantastic results Leo! Would you mind sharing more details about how you made a double stack with two Lunt CaK filters?
~ Petrus ~
Flickr
Flickr
- Has thanked: 20962 times
- Been thanked: 10593 times
These came out very well Leo!
Thank you all, very appreciated!
I'm curious to make measurements of filters, also B600 i have is quite old and the band could migrate significantly
see the picture below
sorry for belated answer
Leo
I was inspired by your recent CaK SS/DS tests
I take the only 2.4A B600 filter from the second Lunt CaK and put it right next to B1800. As it was only the first test, I connected it with a flexible rubber gasket that could be tilted and seen in live mode on the screen.
Leo
- 20230531_211315 B1800&B600.jpg (298.48 KiB) Viewed 425 times
- Has thanked: 9387 times
- Been thanked: 6201 times
- Petrus
Thank you for your answer, I might try this one day with my Lunt12mm too!LeoD wrote: ↑Wed May 31, 2023 7:19 pm Thank you all, very appreciated!I was inspired by your recent CaK SS/DS tests
I'm curious to make measurements of filters, also B600 i have is quite old and the band could migrate significantlyI take the only 2.4A B600 filter from the second Lunt CaK and put it right next to B1800. As it was only the first test, I connected it with a flexible rubber gasket that could be tilted and seen in live mode on the screen.
Leo
~ Petrus ~
Flickr
Flickr
