Hello,
as some of you know already I watch the solar prominences with a spectro-coronagraph (a coronagraph where the h alpha filter is replaced by a diffraction grating).
Two days ago I bought a 12 nanometer Ha filter for some experiments in my spectro. I used to use a high pass filter to isolate roughly the Ha from the rest of the spectrum. A red filter for the deep sky observation of around 60 -70 nm bandwidth ( 600-700 Angstroms).
Of course these kind of filters are not at all suited for solar observations as its far too dangerous for the eyes and the prominences wont be seen.
Still , I set my 12nm filter in the ASI 178MM and started to look for the Ha line on the screen of my laptop as I was starting my session of prominence observation this afternoon with this new filter.
Accidentally I first found the zero order of diffraction and on the screen appeared the image of the entrance slit of the spectro coronagraph. The LYOT stop was set properly in order to stop the instrumental light diffusion and then enhance the contrast.
Here is what I saw on the screen :
So, in fact I could see the solar prominences with a 120 angstroms H alpha filter . I could see them with the CAMERA ONLY.
I tried visually and the prominence was visible but the contrast was much lower than the image with the camera.
I then tried (with the camera) with the wide band filter and no prominences could be seen.
It suprised by as usually the sky in Paris is so hazy that it s not supposed to allow this kind of observations with such a filter.
Here are the photos with my spectro coronagraph and the 1200 l/mm grating.
Chris.
An unexpected result with an 12nm H alpha filter
- Has thanked: 259 times
- Been thanked: 237 times
- Has thanked: 1071 times
- Been thanked: 1985 times
Re: An unexpected result with an 12nm H alpha filter
That is so awesome. It's stuff like this that just says how real the world can be and that we can actually see things and make discoveries.
- Been thanked: 16693 times
It's amazing that you could see and image the prominences at such a wide bandpass. Superb!!
- Has thanked: 2977 times
- Been thanked: 2082 times
Interesting, what are the bright specks apart of the prominence? Dust?
Triband C9.25
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
- Has thanked: 20424 times
- Been thanked: 10243 times
Great result indeed!
- Has thanked: 175 times
- Been thanked: 426 times
This is really good. Have you posted the design of your spectro-coronagraph?
This may be of interest, by Klaus_160. He took prominence images through a coronagraph and various filters, including no filter.
https://www.cloudynights.com/topic/7569 ... ominences/
George
George
