FD solar chromosphere mosaic from last December (29 panel)
- Has thanked: 902 times
- Been thanked: 555 times
Hi to all
I've just uploaded on Astrobin my last H-Alpha solar chromosphere mosaic (29 panels).
Images are from the last December 2022 (20221220). I used my FLT 132 apo, with a full aperture D-ERF, TZ4 lens and a SolarSpectrum SO 1, 0.5A
Seeing wasn't so good, sun very low, but result isn't so bad.
Here the link to full resolution images/data:
https://www.astrobin.com/9smtk2/
https://www.astrobin.com/ioe0y2/
https://www.astrobin.com/giqdjp/
https://www.astrobin.com/r2m7c8/
and images:
Bye
and images:
Bye
- Has thanked: 6305 times
- Been thanked: 7323 times
Re: FD solar chromosphere mosaic from last December (29 panel)
Impressive mosaic Sergio!
Thanks for sharing,
Arne
Thanks for sharing,
Arne
- Has thanked: 20813 times
- Been thanked: 10487 times
Good disk Sergio, you are more patient than me with the mosaics!
I’m lucky to found the allign points for so much panelsmarktownley wrote: ↑Sun May 28, 2023 8:10 am Good disk Sergio, you are more patient than me with the mosaics!
- Ivan
- Has thanked: 3483 times
- Been thanked: 2262 times
Sergio, you are a very patient man. I can imagine how difficult it is to collect so many fragments.
Ivan
Ivan
- Has thanked: 8558 times
- Been thanked: 8290 times
That’s a heck of a mosaic.
With a proper allignment of the camera collectig frames is relativelly fast and also the stack with the batch processing of Autostakert. The problem is to merge the resulting panels and to correct vignetting and off band of my filter.
- Ivan
Due to the changes of seeing, it can be difficult to assemble a uniform mosaic.
What shooting parameters did you use, and how long did it take to shoot one fragment?
If you are assembling a mosaic in Photoshop using Fotomerge, then there is a function for removing vignetting.
Ivan
Ivan
- Has thanked: 17853 times
- Been thanked: 16992 times
They are seamless and very high in resolution. Superb!!
Yes, really difficult... I shot each panel collecting 1500/2000 frames at 76fps or 155fps (12bit or 8 bit) with exposure time of about 4-6/1000s, medium/low gamma to reduce vignetting effect. Than I use autopano pro for the merge, it has a vignetting reducing function but for the out of band zone it doesn't work and I have to correct contracts and sharpening with PS. ThanksIvan wrote: ↑Sun May 28, 2023 8:49 pm Due to the changes of seeing, it can be difficult to assemble a uniform mosaic.
Ivan
Yes, I made some printings of my mosaics and results are really nice.
- Ivan
I understand you, mosaics is a difficult task!
Ivan
Ivan
