5 hours 31 minutes timelapse of AR3310, 3311, 3312 and 3313 in H-Alpha 20th of May 2023
- Has thanked: 6305 times
- Been thanked: 7322 times
Dear friends,
Here are two 5 hours 31 minutes timelapses of AR3310, 3311, 3312 and 3313 in H-Alpha. Both timelapses are created from the same 978 recordings between 09:36 and 15:07UT on May 20th 2023. Each recording was 15 seconds long with a framerate of 45 (675 frames) and 5 seconds delay between each recording.
The recordings where obtained using a using a 90mm Coronado filter in front of a StellaMira 80mm ED f/10, Baader 35nm H-Alpha, BF15 w/Beloptik ITF and ZWO ASI-183mm mounted on a ZWO AM5 mount guided with Hinode SolarGuider.
The 200 frames from each recording was stacked in AutoStakkert!3 before they were aligned, sharpened and contrast stretched in ImPPG.
The frames was then cropped, resized to 2/3 and the animation was created in PIPP at 15fps effectively compressing the 5 hours 31 minutes of duration down to just 20 seconds.
Click on image to view in full size on AstroBin.
AR3311 and 3313
AR3310 and 3312
Arne
AR3311 and 3313
AR3310 and 3312
Arne
- Peterm
- Has thanked: 1806 times
- Been thanked: 1564 times
Re: 5 hours 31 minutes timelapse of AR3310, 3311, 3312 and 3313 in H-Alpha 20th of May 2023
This is so very, very good Arne. That looping flare in the first animation stole the show!
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
- Has thanked: 4379 times
- Been thanked: 3976 times
Very nice work. Fantastic pictures.
- Has thanked: 20813 times
- Been thanked: 10484 times
These are great Arne!
- rigel123
- Has thanked: 8573 times
- Been thanked: 8810 times
Excellent Arne!
Thank you very much Peter, Petr, Mark and Warren!
Arne
Arne
Many thanks Aaron!
Arne
Arne
Excellent results Arne.
Thanks Maurits!
Arne
Arne
- Has thanked: 9318 times
- Been thanked: 6156 times
Excellent animations, Arne. You are very dedicated to this !
- Has thanked: 8558 times
- Been thanked: 8290 times
Superb, Arne.
Many thanks Franco and Stu!
Arne
Arne
